0 Members and 1 Guest are viewing this topic. Read 8042 times.
These finishes (all stock finishes) are by Bud Bailey: lite oak, dark oak, cherry.mls stock finish is Satin Black.mls premium finishes are African Ebony, diamond piano black, and rosewood.Piano black has always been the most difficult to produce. Bud used a shiny black film from Japan applied over the MDF. It looked nice but not as nice as a sprayed finish. In sprayed finishes domestic paintshops are constrained by EPA guidelines. Car paint (acrylic) over three coats of primer is typical, bu ...
Quote from: miklorsmithSo, from this, I assume the "SUPER DUTY" cabinets have additional bracing internally?Yes, they have additional bracing and "slightly thicker" HDF (High Density Fiberboard)I posted some pictures of the "thicker cabinet walls" here:http://www.audiocircle.com/index.php?topic=26035If you look at the pics closely, you'll see that the baffles are "VERY" thick.
John... Please note two things here...First... we use ONLY imported MDF. (cool)and second... we use a "type" of mdf that is "higher rated" than what is normally used... This is not BS hype... but a fact. There are several levels of DENSITY (within the mdf) that are available... we use the MOST dense (not me... the mdf... )...This contributes to the overall performance and our ability to "work the finish" the way we like to do... all are important... All the best...mls
Hi Mark,I stand corrected. Then MD MDF it is. (Most Dense MDF )Thanks for stopping in.I know it is hard to be everywhere, but don't be such a stranger
Are there pictures anywhere??Thanks,Bill
Thanks John!Definitely an improvement over before!
Sorry all, but I knew Brian would come to his senses and he has. The special is now over and I will post the new pricing for "upgrading to the Incredible SUPER DUTY MLS cabinets. ...
