0 Members and 1 Guest are viewing this topic. Read 7015 times.
will not yellow with age, is rock hard and water will not harm it (try setting a wet glass on a lacquer finish - it will leave a ring ...
shokunin - Today I rubbed out some cabinets to a high-gloss finish. Although I have rubbed out NC lacquer and pre-cat lacquer in the past, I was never able to get a finish quite as good as this. It is just like glass - crystal clear, hard as a rock and will not yellow with age.- Jim
Steve - No, these were not yours. But I am using the same system on yours and they will be the next I rub out.Your cabinets are finished with the veneering stage. This week they will get the dye, sealer coats and finish coats. Next week they will be rubbed out.- Jim
Quote from: jsalk Next week they will be rubbed out.You must not live in New Jersey as that phrase seems to have a very different meaning there at least when used by folks in the "waste disposal" business. . . Tim
Quote from: jsalkSteve - No, these were not yours. But I am using the same system on yours and they will be the next I rub out.Your cabinets are finished with the veneering stage. This week they will get the dye, sealer coats and finish coats. Next week they will be rubbed out.- JimIim thanks. I know there have been comments about dyed black vs Mahogany or other types of wood. But as you know, when done right, the beauty of the grain and finish can be equally beautiful with blac ...
shokunin - No, these are not water-based, although I understand that ICA also offers them as well. The materials I learned to use last week are all solvent- based, post-catalized materials and are quite expensive compared to anything I have used before. But so far I am very impressed by the results.Today I rubbed out some cabinets to a high-gloss finish. Although I have rubbed out NC lacquer and pre-cat lacquer in the past, I was never able to get a finish quite as good as this. It is just like glass - crystal clear, hard as a rock and will not yellow with age.- Jim
Hi Jim,Here's a link to a product called Crystalac that was recommended to me. I found it to be very impressive with the clearest, hardest finish I've ever seen. Since you're experimenting a bit, check it out.Jimhttp://www.crystalac.com/products.htm
Quote from: jholtzHi Jim,Here's a link to a product called Crystalac that was recommended to me. I found it to be very impressive with the clearest, hardest finish I've ever seen. Since you're experimenting a bit, check it out.Jimhttp://www.crystalac.com/products.htmIf it's as good as they say, they have a lot of interesting stuff. I can also recommend products from Behlen Bros. (http://www.hbehlen.com) Everything of theirs I've used has been good quality.
Jim,Are they my speakers? Pelallito
