Basement Plans - Acoustic Opinions Requested
0 Members and 1 Guest are viewing this topic. Read 6565 times.
PhilNYC
Re: Basement Plans - Acoustic Opinions Requested
« Reply #20 on: 2 Apr 2006, 02:31 pm »
Quote from: TomW16
1. How does an approximately 25' x 15' x 7.5' room look acoustically? I realize that the 25' and 15' are both multiples of 5 but note that the widest portion of the room will be approximately 16.5' and the narrowest portion of the room will be 11'.
15' = 2 x 7.5', so that will also bring on some issues...
bpape
    • Sensible Sound Solutions
« Reply #21 on: 13 Apr 2006, 01:55 pm »
To answer a question from earlier that I missed in this thread...
If you fill the stud cavities with 703 and then just cloth cover, that can work.  There are a few if's and buts though.
1.  If you do this for the whole room, things will be way too dead.
2.  Wherever you would do this (assuming NOT the whole room), you'll be weakening the isolation to/from the rest of the room by losing the mass of the drywall.  You'll need to caulk the cavities and consider doing double drywall on the OTHER side of the wall.
Bryan
