looking for a quick, cheap jumper cable recommendation
0 Members and 1 Guest are viewing this topic. Read 1741 times.
maxwalrath
I just got a pair of bi-wirable speakers and need some jumpers.
I used a solid piece of copper wire that came with the last pair of speakers I had. I thought it worked fine...thing is I don't know where to get thicker, single strand wire (I have some radioshack multi-strand, didn't try a hardware store yet). I also don't know if that's the best fix. Thanks for any opinions.
bubba966
« Reply #1 on: 11 Mar 2006, 07:00 pm »
I've used 12ga Romex for jumpers before on someone's B&W Nautilus 802's and they were pleased with the results. The speaker cables used were Nordost Valhallas. The jumpers were only there until the Bi-Wire Valhallas came. Gotta say that I was kinda surprised at how good the Romex jumpers sounded...
« Reply #2 on: 11 Mar 2006, 07:05 pm »
tvad4
« Reply #3 on: 11 Mar 2006, 07:16 pm »
I use Canare 4S11 starquad cable on my Von Schweikert VR4 Gen III. $.69/foot from Markertek.com (no minimum). You can use it bare wire, or add terminations of your choice depending on how much you want to spend.
maxwalrath
« Reply #4 on: 11 Mar 2006, 07:46 pm »
The $0.69 stuff is about the price I was thinking of. My system has changed since the last time I bi-wired, but I couldn't hear the difference between pricey jumpers and the single strand copper wire.
tvad4
« Reply #5 on: 11 Mar 2006, 07:53 pm »
Quote from: maxwalrath
Me neither.
http://www.markertek.com/SearchProduct.asp?off=0&sort=prod
BTW, Von Schweikert recommends connecting the primary speaker cabling to the midrange/tweeter and running the jumpers to the bass module. Don't know how that would affect your speakers, but the concept makes sense to me.
kfr01
« Reply #6 on: 11 Mar 2006, 08:18 pm »
Big fan of the $0.69 canare 4S11 too.
maxwalrath
« Reply #7 on: 11 Mar 2006, 08:31 pm »
nice. I'm about to order a bunch of it.
