0 Members and 1 Guest are viewing this topic. Read 39593 times.
You might want to try an earlier version of Slimserver.6.5 is still in beta. I personally use 6.2.1 with Firmware 15.
Tony,I do not know. I use 6.2.1 and I am very happy with it. I have never tried any of the "newer" releases. Perhaps someone else here can answer this question.
Well, in my case George I will need to upgrade if I want to use the Nokia 770 skin. I have one of these little jobbies and running the supplied skins just does not cut it. The 770 skin is only built for 6.5 or better.
Will I still hear a difference with firmware v15?
Is the V15 firmware the "audiophile" version simply due to the volume and polarity issues?
Jim,Thanks. V15 sounds good to me; not sure where it's any better, but it clearly sounds good. It's not instantaneous to switch FW (unplug, redo WEP setup) so I'll trust everyone's ears (especially yours ) and assume if it ain't broke don't fix it.
George,As I mentioned in the earlier post, I play with polarity from my Bent TAP remote on a song by song or disc by disc (i.e one off) basis anyway, so no worries. ThxTed
