Experience with D100
Bill Baker
    • Musica Bella Audio
« on: 10 Mar 2006, 02:46 pm »
Greetings everyone,
 I recently received a pair of D100 amplifiers to experiement with in conjunction with the Bella loudspeakers. With the higher efficiency of these speakers, I felt the 100 watt D100 should be plenty.
I now have them driving a pair of my Musica Bella SP/AV-2 speakers (96dB / 4 ohm) and pleasantly surprised with how musical, yet refined the presentation is. It was apparent after only a few moments of listening. Excellent resolution, inner detail and transparency. The dynamics of this combination is exceptional as well.
 The noise level is non-existent with these very high efficient speakers which is one of my initial concerns with any amplifier.  I am using the ModWright 9.0SE in front with a Custom Level II Jolida JD100 CD player and my RAM CD25 (Highly modified Music Hall CD25 which Dan Wright  designed for me a few years back with his tube output stage). I can't wait to get my vinyl rig up and running. The table is here, Music Hall MMF-9, just waiting for a phono stage to arrive.
 Power cords feeding the amplifiers are VH Audio Flavor 4 with Jam'n Audio PRO14S feeding the preamp and source components.  Interconnects are Eichmann eXpress 6 and speaker cables are Unity Solid Link.
 Next week, I will switch the Bella 2 for the Bella 1 at 90dB/8 ohm.
In all fairness, I do not have other similar designs to compare to at this time but it doesn't take long to realize good music when you hear it and I am convinced already that these amps are an exceptional match with my Musica Bella speakers.
 Nice job Dusty.
StevenACNJ
« Reply #1 on: 10 Mar 2006, 02:57 pm »
After reading the results from the recent digital amp comparison event, it appears that the UCD based digital amplifiers like balanced power.
If you have a balanced power conditioner, perhaps you could do a comparison.
Bill Baker
« Reply #2 on: 10 Mar 2006, 03:26 pm »
 Nope, that I don't have. You have to remember, I'm a tube guy 99.9% of the time.
Charles Calkins
« Reply #3 on: 10 Mar 2006, 03:33 pm »
I prefer to run my D-200's directly into a wallwart. My ears seem to tell me when they are run through a lineconditioner they seem to have a veil or something like that. Whatever it is it's subtle.
                             Cheers
                            Charlie
Bill Baker
« Reply #4 on: 10 Mar 2006, 04:32 pm »
I personally do not like to run ANY amplifier through a line conditioner. When I can avoid it, I don't use a line conditioner at all. Wait a minute, I don't own one.
 The D100s are plugged into an Eichmann eXpress power bar being fed by their own power cord. I am only doing this to be able to accomidate all the components within the system.
ted_b
« Reply #5 on: 10 Mar 2006, 06:25 pm »
Quote from: Charles Calkins
                             Cheers
                            Charlie
Charles,
What do you mean by "straight into a wallwart"?  Is there a wallwart like device that the CIA D200's use?  I assumed an iec connector, a decent aftermarket pc and into the wall, unemcumbered.  Thanks,
Ted
Bill Baker
« Reply #6 on: 10 Mar 2006, 06:39 pm »
Yes, the CI Amps do have an IEC where you can use your power cord of choice. As mentioned in my original post, I am using VH Audio power cords. Maybe what he ment by "wal wort" was the AC recepticle at the wall?
Charles Calkins
« Reply #7 on: 10 Mar 2006, 06:40 pm »
ted-b:
 I guess I should have said just a regular electric wall socket.
                Cheers
                     Charlie
woodsyi
« Reply #8 on: 10 Mar 2006, 06:46 pm »
Well, my fancy dedicated outlets with cryoed Porter plugs sure stick out like warts.  :wink: Bill, Wouldn't unlimited regenerated pure AC power be like Mana to tube amps?
