Quick ACI Force Sub Question
drcruz
« on: 8 Mar 2006, 05:53 am »
What's the sensitivity of the Force Subs???
1V = ??? SPL's
Thanks in advance  :)
Mike Dzurko
Re: Quick ACI Force Sub Question
« Reply #1 on: 8 Mar 2006, 06:32 pm »
Quote from: drcruz
1V = ??? SPL's
It is variable, just depends where you have the volume control set  :D There's enough gain to match anything up to about 105db 1 w/1m
drcruz
« Reply #2 on: 8 Mar 2006, 09:31 pm »
Thanks Mike,
The reason I'm asking is that I want to use stereo Force Subs out of a Transformer Vol Cont. passive Pre-amp and I think the component w/ the lowest volts out will be about 1 Volt. from the phono amp
Pre-Amp = http://www.diyhifisupply.com/diyhs_django.htm
Phono Stage = http://www.diyhifisupply.com/diyhs_cole.htm
So I hope this works.
Everything I read about your Force subs in stereo sounds great, and I'm REALLY looking forward to purchasing.
I currently run a 12 in. SpeakerCraft sub and I get good SPL but muddy sound in my room.  My room is 17 wide x 29 long x 9 high, my system is along the short wall and I sit 12 feet back.  I did the Pi x R sq'd number crunch, so I'm looking forward to I getting more surface area from the stereo Forces, the benefits of stereo placement, the speed of 10 inch drivers and the build quality ACI is known for.  :D
Anyway thanks for your time.
Mike Dzurko
« Reply #3 on: 9 Mar 2006, 12:52 am »
Quote from: drcruz
Thanks Mike,
I currently ...
Stereo Force subs will work GREAT for you. Make sure to take advantage of the special pair pricing  :D   And then make sure to come back with your impressions!
drcruz
« Reply #4 on: 9 Mar 2006, 04:20 pm »
GREAT NEWS...
Thanks,  :mrgreen:
