Acoustic Zen MC2 vs. Harmonic Technology Digital Platinum
0 Members and 1 Guest are viewing this topic. Read 5536 times.
movie_fan
Hi,
I asked my local hifi supplier for an Acoustic Zen MC2 digital cable to try out.
Unfortunately, the importer has these out of stock...  :?  So, the hifi supplier suggested the Harmonic Tech Digital Platinum digital cable.
What can I expect from the Harmonic Tech? Better? similar to the AZ's?
Cheers!
arthurs
« Reply #1 on: 7 Mar 2006, 02:07 pm »
I just got a Stereovox HDVX and it is an excellent digital cable for reasonable dollars....you can find them on audiogon all the time.  FWIW, I have an all Zen system and didn't much care for the MC2....
movie_fan
« Reply #2 on: 7 Mar 2006, 02:12 pm »
Well, I heard the MC2 at someone else's, and liked it. That's why I wanted to try one.
Also, I've read quite a few good things about that HDXV...
arthurs
« Reply #3 on: 7 Mar 2006, 02:20 pm »
You might drop a note to Phil at Sonic Spirits, he's an AZ dealer and really excellent to work with....my experience would be if you've heard a cable and liked it a lot, hold out for that cable....
electricbear
« Reply #4 on: 7 Mar 2006, 08:58 pm »
Peter Lee is the owner of Acoustic Zen, he used to be with Harmonic Tech.
I think you'll find that the cables are similar sounding. I'd wait for your dealer to get in some Acoustic Zen as Peter is a super nice guy and deserves all the business he gets.
PhilNYC
« Reply #5 on: 7 Mar 2006, 09:14 pm »
Quote from: movie_fan
Well, I heard the MC2 at someone else's, and liked it. That's why I wanted to try one....
The MC2 was designed for use with AES/EBU (XLR) digital interface.  It is 110ohms, and not the best for the SPDIF (RCA).  If you like AZ stuff and use SPDIF (RCA), take a look at the AZ Silver Byte.
arthurs...thanks!
electricbear...it's Robert Lee, not Peter.  And yes, he is one of the nicest guys I've met in the industry... :D
movie_fan
« Reply #6 on: 8 Mar 2006, 11:12 am »
Quote from: PhilNYC
Well, in fact that's another doubt I have. Is it worth having a 110 ohms cable, and then having it with RCA terminations? That also applies for the Harmonic Tech Premium...  it's also a 110 Ohm cable.
PhilNYC
« Reply #7 on: 8 Mar 2006, 12:25 pm »
IMHO, no (that was kind of my point).  Getting a 110ohm terminated with RCA for SPDIF use is not the right thing to do.  At least look for a 75ohm cable (like the AZ Silver Byte), and if you have the ability to connect via BNC, that's better than RCA...
DSK
« Reply #8 on: 8 Mar 2006, 01:25 pm »
Quote from: PhilNYC
...Getting a 110ohm terminated with RCA for SPDIF use is not the right thing to do....
I wondered about this too ...until I heard it. It was significantly better than the HT copper, HT silver, Transparent Audio and Audioquest digital cables that I auditioned (by a greater degree than I thought possible between digital cables). Haven't heard the AZ.
movie_fan
« Reply #9 on: 8 Mar 2006, 03:07 pm »
So, nothing like trying, right?
PhilNYC
« Reply #10 on: 8 Mar 2006, 03:09 pm »
Yep... :D
ekovalsky
« Reply #11 on: 8 Mar 2006, 06:15 pm »
I use two MC2=Zen (one S/PDIF and one AES-EBU) in my setup.  Very happy with both.  I've tried some other good digital cables including Pure Note, Nordost, Argent, Tara Labs, and VH Audio.  I did not find great differences among most of these, and the MC2 remain in my system.
The only non-AZ digital cable in my setup is a S/PDIF VH Audio Pulsar with Silver Nexgen connectors.  I use it between the transport and RCS 2.2X.  Great cable with a very similar sound to the S/PDIF MC2.
A friend has recommended the Cerious Tech digital cables but I have not had the chance to try them yet.
