Terminal Plate Envy!
Aether Audio
    • http://www.aetheraudio.com
« on: 3 Mar 2006, 06:23 am »
Guys,
Don't you wish your speakers had terminal plates that look this cool.  8)  Ok...maybe not.  But handles do come in uh...er..."handy." :roll:   Not only for moving the speakers, but the entire crossover network is attached on the other side by stand-offs.
In the event of a failure (only one so far), you just take out the outer screws, pull out the module (the handles are a life saver here because of the tight gasket seal), disconnect the wires...and ship 'er back.  Beats the heck out of shipping the whole speaker back - especially the floor standers!  Ahhh...field serviceability.  You learn that real quick when you work in industrial design.  Just another little "plus" from SP Tech. :wink:
-Bob
mixsit
« Reply #1 on: 5 Mar 2006, 04:09 am »
Bob, how about quick run down on the dual-post options? When I first plugged in (sans manual :roll: ) I was surprised to hear only the top (or low) end. I figured by-wiring but assumed that that meant they would combine at the x-over. By-amping?
Thanks.
Wayne
