Integrating SB2/3 into 2 Channel/HT System
0 Members and 1 Guest are viewing this topic. Read 1429 times.
rklein
  • My finest audio piece ever!!
« on: 28 Feb 2006, 07:23 pm »
Hi All:
I am very interested in going down the SB2/3 route for my 2 channel listening.  My system does double duty for 2 channel as well as HT.  I would like to sell my Odyssey Etesian Preamp(passive) and use the SB2/3 with Analogue mods directly into my Odyssey Khartago amp.  However, since I would no longer have the Etesian(which had an HT bypass), I am trying to figure out how to use my system for watching movies/TV.  One solution might be a switching device(Niles?)  Another solution would be to have speaker wire coming out of the Khartago amp going to my Nightengale speakers and using this for 2 channel.  Then having another pair of speaker wire going out of my Marantz SR-7200 receiver and just use the receiver to drive all my speakers for movies/TV.  This option would just entail me having to manually switch the speaker wires at my L/R speakers depending on 2-channel or HT listening.  This option would also eliminate the need for a switching device, which is one less component in the signal path.
Can someone else in the same situation comment on possible solutions?
rklein
sleepysurf
  • Member of the Suncoast Audiophile Society
    • Suncoast Audiophile Society
« Reply #1 on: 1 Mar 2006, 03:33 am »
See this thread for a discussion about audio switch options...
http://www.audiocircle.com/index.php?topic=26029&highlight=
Currently, I am using a cheap Radio Shack push-button switch (Catalog # 15-1982), with no appreciable loss of fidelity (despite cheap construction).
I'm feeding both my SB2/Benchmark DAC1 and Yamaha RX-V1000 (with front channel pre-out) into the Rat Shack switch, with single output to my Sunfire Amp.  Very easy to switch between the two.
Still looking for a better quality solution though.
