0 Members and 1 Guest are viewing this topic. Read 27246 times.
All:The coolest thing about it, aside from the improvement, was the way it installed. I plugged the USBTD into my PC, and sat down. I launched Foobar, and went to Prefer ...
Does it replace your windows sound device? In other words, does it play all the Windows sounds, including games and multimedia? It should. Under Start > Control Panel> Sound and Audio Devices > Audio tab, under Sound Playback, how is it listed?
Quote from: boeadDoes it replace your windows sound device? In other words, does it play all the Windows sounds, including games and multimedia? It should. Under Start > Control Panel> Sound and Audio Devices > Audio tab, under Sound Playback, how is it listed?You CAN use it for playing your Windows sounds, but I don't. Not sure I want to be listening to a live show at 75 on my preamp, and have a Windows DIIIIIIIINGGGG!!!! come through at 125dB and fry my ears and tweeters. It's listed as a USB Audio Device I think.
I know that the DIP Superdrive was optimized for long runs of digital cable..., so that might assist with the situation.
That conclusion seems to mesh pretty well with what is widely believed. The optimal coaxial digital cable length is a debated issue, but I doubt anyone would advocate using a 25' run. On the other hand, relatively long runs of USB cable don't seem to be a problem.One comment, though, about USB DACs. It is not necessarily the case that a USB DAC takes the USB signal and converts it to SPDIF. This, unfortunately, is a common approach as one could take a standard SPDIF-input DAC, append some sort of US ...
Hello,I was wondering if anyone has any updates regarding this dac. I am looking at hard drive playback options again and this looks very interesting to me. Is anyone using this with a Mac?
Was it the DAC itself that was updated, the USB interface, or both?Thanks!
