SPECS for ACA 2b and SE 18.
0 Members and 1 Guest are viewing this topic. Read 1620 times.
mbarnes
    • http://www.norh.com
« on: 16 May 2003, 12:23 pm »
I hope to have photos of the final Le Amp II on Wed and we should start shipping after that.  I posted the SPECS for the ACA 2b and the SE 18.
SE 18 Single-Ended Parallel Integrated 18W/Channel Amplifier
Phono Section 12AX7 x 2
Line Stage 12AX7 x 2
Driver Tubes 12AX7 x 4
Output Tubes EL34 x 4
Input Impeadance - Line Stage 100K
Phono Stage 47K (Moving Magnet or High Output Moving Coil) - Output Voltage 4 ohm - 8.5V, Output Voltage 8 ohm - 12V
Frequency Response at 1 watt - 10 - 50,000 Hz
Sensitivity at Maximum Output - Phono 20 mV, Line 150 mV
Power Consumption 200 watts
Price (including shipping) $795.00
ACA 2b Tube Audio Control Amplifier (3 inputs, 1 Record Output, 2 Main Outputs)
Tubes 2 - 6922 Sovteck (SRPP)
90 second delay warmup (softstart)
Frequency Response at 2 Volts RMS 10 - 100,000 Hz
Gain 11dB
Input Impeadance 100,000
Output Impeadance 50,000
Power Consumption 30 watts
Price (includes shipping) $395.00
