0 Members and 1 Guest are viewing this topic. Read 12137 times.
Hi allThought that you might like this image http://www.diyaudio.com/forums/showthread.php?s=&postid=875976#post875976This amp was a Metaxas Solitare, but, now it's a Metaxas GB300D mgalusha, just wondering how your GB300D is going
I see you're using cablepods for binding posts. Do you like them?
Beautiful job, Mike. I can't wait to hear your comments on the sound.Jim
Brad,I do like them but their use was serendipitous... but yup, I do like the cable pods. I don't know if they affect the sound in any way but I do like the way the operate in that the contacts don't rotate so spade lugs don't try and twist ...
Thanks KLe. It's actually the second time I've used this chassis with new boards. The first time was as a home for a set of the LC Audio ZapPulse class D amps. I can say for sure that the SKA's are much more agreeable that the ZAP's were.
