It's not unusual to get a voltage spike on the output when first turning on a tube (or even SS) component. So, I turn on the upstream components one by one. Phono stage, wait a minuite or so for the tubes to come on, then the pre-amp, wait a minuite or so again, and then the power amp. Turn-off is the reverse sequence. No pops this way.
Hiss can come from noisy tubes. That would be my first guess. Only way to check is to swap tubes and see if it makes a difference. Not unusual to find a noisy tube every once and awhile. That would be the AU7 tubes, not the rectifier.
Best of luck.
