What power amps are you using with the Purist.
DaveX
« on: 19 Feb 2006, 04:39 pm »
I am currently using a Cary 94L preamp with the Channel Islands D200 monoblocks, the cary sounds good but it's costing me a fortune in mullard 12AU7's, these are the only tubes I like as I find other 12AU7's too bright and toppy. I could do with a bit more detail and more bass definition and was wondering if the Purist would be a good match with the D200's. Thanks. I'm from the UK.
marvda1
  • freelance reviewer: The Sound Advocate
« Reply #1 on: 19 Feb 2006, 05:46 pm »
have you tried the groove tube mullard re-issue at $26 us  each?
see link below.
http://www.groovetubes.com/tubes_list.cfm?ObjectGroup_ID=107
balji
    • http://www.highdefzone.us
« Reply #2 on: 21 Feb 2006, 01:03 pm »
Hi
I have tried the Purist with NuForce Reference 9 mono blocks and the combination has produced some of the greatest music, I believe the purist will also do wonders for the D200.
Thanx
