Tape output.
0 Members and 1 Guest are viewing this topic. Read 5220 times.
DaveX
Tape output.
« on: 18 Feb 2006, 06:36 pm »
Doe's the Purist Preamp have a tape output. Thanks.
westcoast
Tape output.
« Reply #1 on: 19 Feb 2006, 01:23 pm »
Hi DaveX, I'm linking you to the "Specifications" page on the Purist at the IRD Audio site:
http://www.irdaudio.com/products/purist-specs.htm
If this info doesn't answer the question for your particular situation, shoot an email to Curt at [email protected]/  He'll get you squared away.
giannettino
Re: Tape output.
« Reply #2 on: 19 Feb 2006, 01:54 pm »
Quote from: DaveX
Try here.. :o
http://www.audiocircle.com/index.php?topic=13327
Ciao
Gianni
DaveX
Tape output.
« Reply #3 on: 19 Feb 2006, 04:56 pm »
Thanks guys, I don't use my tape deck a lot and always monitor with headphones.
"Preamp gain set to zero db and turn the volume all the way up with power amp/s turned off."
