Felix project
*Scotty*
Re: Felix project
« Reply #300 on: 2 Nov 2010, 11:08 pm »
They all have an x2 rating which means they are appropriate for the application across the hot to neutral lines.
Scotty
jtwrace
    • TIPP YouTube Channel
Re: Felix project
« Reply #301 on: 3 Nov 2010, 12:19 am »
Scotty
OK.  So you're saying these are the proper ones?
JDUBS
Re: Felix project
« Reply #302 on: 3 Nov 2010, 01:45 am »
Define proper.  They are x2 rated caps.
jtwrace
Re: Felix project
« Reply #303 on: 3 Nov 2010, 01:48 am »
recommended for this project.  The "best"!
*Scotty*
Re: Felix project
« Reply #304 on: 3 Nov 2010, 02:05 am »
jtwrace
Re: Felix project
« Reply #305 on: 3 Nov 2010, 02:12 am »
This is the series that was originally speced,I don't know which is best sonically speaking.
http://search.digikey.com/scripts/DkSearch/dksus.dll?WT.z_supplier_id=56&WT.z_page_type=SP&WT.z_page_sub_type=SS&WT.z_oss_type=Keyword&v=56&lang=en&site=us&KeyWords=Vishay%2FBC+MKP+338+X1&x=8&y=10
Scotty
Thanks.  Hmmm.  I might have to call my Vishay contact on this one.   :scratch:
Big Red Machine
Re: Felix project
« Reply #306 on: 3 Nov 2010, 12:36 pm »
Where did the name Felix come from?  The Cat?  Why?
jtwrace
Re: Felix project
« Reply #307 on: 9 Nov 2010, 12:24 pm »
Here is the answer from my Vishay contact.
The 338 1-serie is an X1 cap 440Vac
The 338 2-serie is an X2 cap 310Vac
Both series are not the same.
The 338 1-serie is used in industrial applications (3 phase)
When the 338 2-serie is for standard applications (1 phase)
See also the RFI application note
If you would like the PDF emailed to you just email me.  My email is in my profile.
Occam
Re: Felix project
« Reply #308 on: 9 Nov 2010, 03:09 pm »
The original Lab power conditioner project was called Felicia, in honor of JoshK's wife. Based upon Jon Risch's Q&D digital filter, it used surplus back to back transformers to supply filtered balanced power to source components < 100va. The follow up project, less limited in current capabilities, smaller, using off the shelf parts, and with overall better performance was simply given the masculine version of the name Felicia, Felix.
Fe·lix   
[fee-liks]
–noun
a male given name: from a Latin word meaning “happy, lucky.”
Felicitations,
Paul
Occam
Re: Felix project
« Reply #309 on: 9 Nov 2010, 03:34 pm »
The X1 rating is implicitly higher than an X2's, and an X1 can be used anywhere an X2 is called for. The reverse is not true. This would provide a higher in circuit dV/dt from the X1 cap assuming equal dV/dt s at rated voltages.
S Clark
Re: Felix project
« Reply #310 on: 9 Nov 2010, 04:58 pm »
Quoted GBB:
"I listed the CMC part number.  A quick google search would have turned up the following data from Coilcraft's website.  Use the CMC with the appropriate ratings for your application.  As others have noted, the current draw of the Squeezebox is minimal, so the 3717 seemed like the right choice here.
---Gary
               Common        Diff.          DCR          Volt.          Amp.
               Mode L         Mode L
P3717-A    25.0            1000          0.30         1500             3
Q4007-A    4.5              150           0.06         1500             5
Q4018-A    1.5               35            0.02         1500            10"
I'm late coming to this thread.  I just checked CoilCraft and they have the P3717-a on backorder.  Obviously there are other options, but not understanding what they do, I am reluctant to substitute.  What if the effect of changing values?
Scott
jtwrace
Re: Felix project
« Reply #311 on: 9 Nov 2010, 05:00 pm »
You want part # P3717-AL that is the RoHs part #.
That's why it's on backorder.
S Clark
Re: Felix project
« Reply #312 on: 9 Nov 2010, 05:12 pm »
Thanks- order placed  :D
samsagaz
Re: Felix project
« Reply #313 on: 11 Nov 2010, 01:50 am »
where can i puchase others  P3717-AL or sustitutes (cheap ones)
S Clark
Re: Felix project
« Reply #314 on: 11 Nov 2010, 01:53 am »
Coilcraft.com
Mravinsky
Re: Felix project
« Reply #315 on: 12 Nov 2010, 10:08 am »
Scott. Have you ordered a 36 pcs tray (of Coilcraft p-3717)? If so, could you sell me 5 of them?
jtwrace
Re: Felix project
« Reply #316 on: 12 Nov 2010, 12:11 pm »
You know that you can purchase as little as you like.  RIght?
S Clark
Re: Felix project
« Reply #317 on: 12 Nov 2010, 02:15 pm »
Sorry, I just order one to build out one Felix and see if it does what I am looking for.
Big Red Machine
Re: Felix project
« Reply #318 on: 14 Nov 2010, 02:34 pm »
Felicitations,
Paul
Thank ya Paul!  I was going to go and make a label for my Felix unit using Felix the cat photo.  Not that it has anything to do with this but it looks cool.
I finished the first unit this morning after delays from other projects.
jtwrace
Re: Felix project
« Reply #319 on: 14 Nov 2010, 02:36 pm »
PICS!!!   :thumb:
