550 and 350 owners- What amp(s) did you use before..
0 Members and 1 Guest are viewing this topic. Read 5581 times.
Parnelli777
the AVA units?
What led you finally to the AVA Fet Valve?
Dan Kolton
« Reply #1 on: 15 Feb 2006, 02:55 pm »
I'd have to go back to the 1980s to talk about any amp other tha AVA.  Back then, it was Audio Research (both pre and power).
ricmon
« Reply #2 on: 15 Feb 2006, 04:48 pm »
a pair of NEW A-20's.  They were pretty nice soundig.  Just did't have the balls to make my speakers sing.
budyog
  • I don't listen to audio, I listen to music.
« Reply #3 on: 15 Feb 2006, 10:06 pm »
Knowing Frank has stayed in the business for so long and hearing some of his modified Dynaco stuff long ago, I purchased the T7-SLR and then I  had to have one of his amps to go with it. I don't even think of going to any other amp. I just want to get my amp and preamp upgraded now to the Ultra and eventually get another 350 Ultra. One for each channel! I had some pretty good amps made by another local guy who has since quit the audio business. AVA gear is superb! I am very, very happy. :D  :D
mark funk
« Reply #4 on: 15 Feb 2006, 11:31 pm »
Well, My first component set was a Pioneer M-22 class A amp, C-21 pre. The amp burned up in a year and a half. Then a Son of Ampzilla, then we went for more watts with a Dynaco 416 with the C-100 capacitor bank. And as we all know the 416 was kinka borrowed from Frank! Went for more watts again with a Carver TFM-25. The FetValve 550 is in a hole different class then these amps and most others at any price! :smoke:
Rocket
« Reply #5 on: 15 Feb 2006, 11:35 pm »
Hi Ricmon,
At last a comparison that i can use as a yardstick.  I had a pair of n.e.w. 20.1's and they sounded pretty good.  Apart from more power what improvement do you think the van alstine amps delivered compared to the 20.1's?
Regards
Rod
tonyptony
Re: 550 and 350 owners- What amp(s) did you use before..
« Reply #6 on: 15 Feb 2006, 11:37 pm »
Quote from: Parnelli777
the AVA units?
Parnelli777, I recently posted my thoughts about the transition to a 550. I won't repeat it, but you can read it here
http://www.audiocircle.com/index.php?topic=25432
ricmon
« Reply #7 on: 16 Feb 2006, 02:45 pm »
Quote from: Rocket
Hi Ricmon,
Regards
Rod
I had the original A20's.  That first batch did not have the quality parts that the 20.1 had.  As compared to the 550 exr.  But before I gat my 550 I had a 350 HC.  The first thing was that I finally got to hear what my speaker are capable of.  The next thing I notice was the sheer extension of the frequency spectrum and more musical clues were washing over me in a way I had not experienced before.  By the way I was using a NWE P3 preamp, nice match but was to tubby.  Next I upgraded to the 550 EX then EXR and this was the most dramatic change of all then I got a TR7 and all I can say is now my system exceeds my NEW set up in every area.  What pre amp are you using?
Rocket
« Reply #8 on: 17 Feb 2006, 01:14 am »
Hi Ricmon,
Pm sent instead of corrupting this thread with non van alstine equipment.
regards
Rod
Zheeeem
« Reply #9 on: 18 Feb 2006, 04:40 pm »
I had Van Alstine Omega stuff, and before that Van Alstine Mosfet.  I now have a 350 (and the older Mosfet).  It all sounds pretty good and it's rugged as hell.
boead
« Reply #10 on: 19 Feb 2006, 06:44 pm »
Quote from: ricmon
What speakers do you have?
ricmon
« Reply #11 on: 21 Feb 2006, 02:40 pm »
Aerial Acoustic Model 5's.  I love these speakers (mated with a sub).  I went the route of upgrading my amp instead of the speakers.  Since inserting the AVA amp (first interation was a 350hc) the speaker are now doing what they were designed to do.  Make music.
