Cleaning MLS cabinets
0 Members and 1 Guest are viewing this topic. Read 1624 times.
CornellAlum
« on: 14 Feb 2006, 02:27 am »
Now that all of the surgeries on the 626r's is complete, what is the reccomended way to clean the high gloss MLS cabinets without scratching them, etc.  I have read that just soap and water is the best way, but I wanted to be certain before starting.
KJ
« Reply #1 on: 14 Feb 2006, 03:15 am »
I've used a furniture wax in the past to try clean up the finish on a non-MLS cabinet.  Don't know the brand though because a custom cabinet shop gave it to me au gratis.  I believe Brian has recommended a good car wax in the past.  Not sure I'd take soap and water to any speaker cabinet, but I'm not as familiar with the finish of the MLS cabinets.  Maybe a clean, damp cotton cloth instead?
-KJ
gitarretyp
« Reply #2 on: 14 Feb 2006, 03:32 am »
I've always used guitar polish and cloth diapers to polish my guitars. The finish is a little different but not terribly so. The polish can be picked-up at any guitar or music store (i like the martin brand, personally), and you can get cloth diapers at walmart in the auto cleaning/polishing section.
John Casler
Re: Cleaning MLS cabinets
« Reply #3 on: 14 Feb 2006, 04:05 am »
Quote from: CornellAlum
Any good furniture polish should work fine. (even Pledge)
I wouldn't use furniture "oils" or such since the finish is not that pourous to the wood itself.
A good grade wax with maybe a little lemon oil (like I said Pledge) should clean and shine just fine.
Do not spray this in a way that gets it on the neo-panels or ribbon tweeter :nono:
EProvenzano
« Reply #4 on: 14 Feb 2006, 04:17 am »
I'm not at all surprised by the advise to use soap and water.  My family has worked in the auto repair business for over 4 generations.  They most commonly recommend a mild solution of dish soap and soft water when cleaning automotive finishes.  Typically these finishes are topped with a clear urethane (clear coat)  that tends to show fine line scratches easily, so proper cleaning is of upmost importance if you want to maintain a showroom shine.
OTOH, auto finishes are highly durable, and I can't say the MLS top coat is equally durable.  Your best bet is to ensure you use a very soft, lint free cloth.  Cotton diaper cloth is a good suggestion.
I'm adverse to most of the cleaning recommendations listed so far, on the notion that they involve adding a foreign substance to your finish.  These are far more likely to react with the finish in an adverse way, as compared to plain old soap and water.
Good luck.
EProvenzano
« Reply #5 on: 14 Feb 2006, 04:21 am »
By the way, plain old soap and water has kept these speakers looking like they did the day I brought them home 3 years ago.....
Good luck!
  • Speakers....What Speakers ?
« Reply #6 on: 14 Feb 2006, 04:25 am »
A good chamois can come in handy as well.... :wink:
    [/list:u]
    warnerwh
    « Reply #7 on: 14 Feb 2006, 04:36 am »
    This stuff is expensive but worth it.
    http://woodworker.com/cgi-bin/FULLPRES.exe?PARTNUM=130-961
    Stuff like Pledge according to people in the industry doesn't do anything any good.
