VHP-1 - possible dumb question
thermalbum
« on: 12 Feb 2006, 04:49 pm »
I am thinking of building a headphone only system in my basement/mancave and I was wondering if it is feasible to hook up 3 sources to the VHP-1 if two use a Y adapter ie. CDP/tuner and the other input would have a TT/VPP-1.
CIAudio
« Reply #1 on: 12 Feb 2006, 05:46 pm »
VHP-1 has only one input so you need something to switch the inputs. A "Y" adapter is a bad idea because the source will be feeding the VHP-1, and also the output of the other device connected to the adapter.
thermalbum
« Reply #2 on: 12 Feb 2006, 05:57 pm »
Thanks -           I'll see if there are any switches available
unityaudio.ca
« Reply #3 on: 14 Feb 2006, 03:14 am »
Niles make a very good one   http://www.nilesaudio.com/images/PS-1hi.jpg
CIAudio
« Reply #4 on: 14 Feb 2006, 04:34 am »
He needs to be able to switch between three sources...looks like the Niles only has two inputs.
giorgino1
« Reply #5 on: 14 Feb 2006, 02:10 pm »
CIAudio
« Reply #6 on: 14 Feb 2006, 03:34 pm »
You could try this:
http://www.decware.com/newsite/rotary.htm
Yep, that should work.
unityaudio.ca
« Reply #7 on: 14 Feb 2006, 03:37 pm »
Quote from: CIAudio
Must be having a "blond" day.  :oops:
BradJudy
« Reply #8 on: 14 Feb 2006, 08:08 pm »
Here's another option that gives you three inputs and two selectable outputs (so you could use the sources with another system as well).  I haven't used one, but they have been recommended a few times on a couple of different forums:
http://fidaudio.com/quintete.html
dhiebert
    • http://darrenhiebert.com
« Reply #9 on: 14 Feb 2006, 11:14 pm »
Quote from: BradJudy
According to the "Order" link on that site, he is no longer taking orders. Does anyone know differently?
thermalbum
« Reply #10 on: 15 Feb 2006, 08:04 pm »
The DECWARE switch looks promising. Now to decide if I do a mancave system or get a new radio control model sailplane
Thanks for the info
unityaudio.ca
« Reply #11 on: 16 Feb 2006, 03:15 pm »
There's also this one by Canadian company "amx" sold at most local shops in Ottawa:
Robert57
CI VPC-2
« Reply #12 on: 2 Mar 2006, 12:49 am »
As a newbie, I realize the immediate need in this thread was for three inputs, but would the CI VPC-2 controller also be an excellent switch candidate for two inputs, to connect a headphone amp to a source or preamp? One preamp I'm considering does not have a tape in/out --just two pre outs. Would it be a good idea to use the VPC-2 after one of the pre outs to switch between the CI VPH-1 head amp and ,say, a sub? Or would it be better to place the controller/ switch after the source (SB2, SACD player) and before the preamp? I worry that any attenuation and/or connection in the chain is bound to detract form the sound somewhat. And this assumes an SB2 (Bolder full mod) could drive the VPH head amp directly.
Thanks.
Rob
CIAudio
« Reply #13 on: 2 Mar 2006, 01:14 am »
You can use the VPC-2 as a 2 input switch. You would use the 2nd pair of outputs set to "fixed" output (bypassing the volume control).
