0 Members and 1 Guest are viewing this topic. Read 10156 times.
BTW, on my 40s I found better sound by inverting the positions of the MW & standard woofer (lowbass on top, midbass below). It's more difficult to perform this mod than it sounds. Go way back & read the threads on it.
I should say that I'll be taking the RM40s apart to add BH5 and will examine the crossovers/change midbass/bass then.
Skynyrd,Thanks for the info. Then I will probably get a pair of RM30s and a sub. Is there a link to Ekovalsky's measurement of the RM/Xs?Thanks.
Though the technique has been around for some time, corner loading a properly EQ'd sub has advantages that are just now being properly publicized. It has exclusive & highly valued advantages, the most impotant being virtually no primary output (all output is boundary-sourced). Read the TacT Audio 2.2X corner-woofer system review in 1/06 TAS. Only my opinion, & YMMV.
It isn't the drivers Eric...
