help me decide a good tube preamp
0 Members and 1 Guest are viewing this topic. Read 3148 times.
peter59
« on: 8 Feb 2006, 05:36 am »
I currently have a 2  channel  S.S. system that sounds great even without room treatments. Recently ordered 8th nerve ADAPT products. They should be here in a few weeks. . I have always wanted to fit a tube preamp into the mix. What would someone suggest for under 2500.00? I listen mostly  to classic rock, and all kinds of jazz.
Current system:
Odyssey Mono Ex amps
Odyssey Tempest pre
Odyssey Loreleis
Symphonic Line CDP
maxwalrath
« Reply #1 on: 8 Feb 2006, 06:12 am »
Modwright. Sounds like an amazing product, multi-award winner, top notch guy behind it, and a better resale value than any other piece out there.
I had a regular Stratos amp a while back, and the beta test version of the Modwright pre was a great match for it.
  • Speakers....What Speakers ?
« Reply #2 on: 8 Feb 2006, 06:14 am »
Quote from: maxwalrath
Yes...as well as the SAS Audio 10A...both very close in sound....and price. 8)
maxwalrath
« Reply #3 on: 8 Feb 2006, 06:16 am »
Never heard a bad word about the SAS either...that's one piece I'd definitely like to try some day.
« Reply #4 on: 8 Feb 2006, 06:18 am »
Never heard a bad word about the SAS either...that's one piece I'd like to try one day.
Steve is running an auditio tour...good for a listen.... 8)
maxwalrath
« Reply #5 on: 8 Feb 2006, 06:30 am »
crap...how did I miss your review Lonewolf? Good review! I saw the tour, I figure let the people that might buy it get a crack at it, maybe I'll see if Steve can pencil me in later.
« Reply #6 on: 8 Feb 2006, 06:32 am »
I think he has two going around....it really is a VG preamp....if I needed another thats one I'd pick up....but I'm loaded enough now.... :?
Tour
« Reply #7 on: 8 Feb 2006, 09:06 pm »
Hi Guys.
     Thanks for the nice comments guys.
     Max, right now there are 7 waiting, and a snag has developed, so the tour is in a holding pattern. So it might be a couple of months. But PM me if interested and we can work something out.
miklorsmith
« Reply #8 on: 8 Feb 2006, 09:08 pm »
The Modwright is insanely good.  Don't know about the SAS.
Price
« Reply #9 on: 8 Feb 2006, 09:52 pm »
Lonewolfny42 auditioned the standard 10A for $1795.00. The  B10A is $1495.00 (includes shipping in the continental USA).
The B10A is the same as the standard 10A except 3 inputs instead of 5 and no monitor section. The sound is exactly the same.
sch
« Reply #10 on: 9 Feb 2006, 12:28 am »
Without doubt, the PRIMALUNA III, for US$1,395 is the best around.
Reviews and info here:
http://www.upscaleaudio.com/product.asp?itemid=499&catid=36
TAS Editor Choice 2005 and Golden Ear 2005
I have it and I love it.
Good luck,
Santiago
Parnelli777
« Reply #11 on: 9 Feb 2006, 01:04 am »
The Wright Sound WLA12A is really an excellent little unit, I'm enjoying the heck out of mine. Less than $900 new. Built by one of the masters.
http://www.wright-sound.com/specs/1
maxwalrath
« Reply #12 on: 9 Feb 2006, 07:49 am »
Steve, what's a monitor section?
« Reply #13 on: 9 Feb 2006, 10:45 am »
What do you want from a tube pre-amp?
I'd recommend matching your wants with the tube signature that best reflects those wants.  Typicaly the small 9 pin tubes have speed/detail, and the larger 8 pin tubes provide tube blume.
« Reply #14 on: 9 Feb 2006, 02:05 pm »
Hi Max,
     The monitor section section allows one to send out the source input to another machine, for adding sound effects, record on tape machine, for signal manipulation etc, and then re-enter into the preamp to hear. One could use an external machine to dubb ones voice onto the source recording, say preparing for American Idol   :) , and hear how one sounds.
