Looking for Cheap Bookshelf Speakers
0 Members and 1 Guest are viewing this topic. Read 5250 times.
« Reply #20 on: 13 Feb 2006, 10:22 pm »
79 dB/w/m efficiency?  Panasonic should be shot for such. :nono:
xluben
« Reply #21 on: 14 Feb 2006, 02:34 am »
Yeah, they are just satellites from my HTIB that costed about $200 with a 5 DVD changer.
The Dayton's shipped today (2 packages for some reason).  According to PE's shipping estimates they should be here in 2 days (the day before my first calc test, perfect).
xluben
« Reply #22 on: 17 Feb 2006, 04:36 am »
After spending a night in my apartment's office I finally got my packages from Parts Express.  Free shipping and it only took two days!
I'm sure the first thing you will notice is how un-ideal my listening situation is :D   But that's all I have right now, so I'm gonna live with it.
Right after I got my packages (8:30AM when the office opened), I had to go to class (9:00AM), so I had to leave my speakers after only a few minutes with them.  When I got back from class I couldn't help myself from putting them together (even though I had a Calc test at 5:30, which didn't go well by the way).  When I started putting them together the first thing I did was take the grills off the enclosures, and pop, one of the ball/socket things broke off.  I was even being careful not to break them!
Anyways, the crossovers were super easy to put together, and I got all the wires set up, and then I had to cut the foam.  This did not go very well, I guess I'm just not good at cutting foam.  I eventually got most of the insides of the cabinets covered and screwed in the drivers (why not pre-drilled?).
 I hooked them up and at first I was very dissappointed with the bass, but then I turned them up, and wow, the bass was there.  It was strong and very tight (way better than my subwoofer).
I still have two satellites and my sub hooked up to one set of outputs on my reciever so I can to A/B testing, and the Dayton's sound much better all around.  They sound more 'alive' and also much more balanced.  The satellites and sub manage to sound thin in the mids/highs, and loose in the bass, while the Dayton's are much better throughout.  And they sound GREAT when I turn them up a little.
Overall, I'm happy with my purchase.  They were a good deal, fun to put together, and I'm pleased with how they sound.
I'd like to make the grills attach magnetically, and I tried cutting small pieces of magnetic tape, but they weren't strong enough to hold up the grills.  Any suggestions on a good way to do this?
