SB2 "wireless" question
0 Members and 1 Guest are viewing this topic. Read 3832 times.
nodiak
« on: 3 Feb 2006, 05:59 pm »
Hi all,
I am taking a leap of faith before I understand this new to me technology, by buying an SB2.
My questions are: the wireless version is more versatle, right ? And, the SB2 can be modded for both analog and digital - you don't have to choose one or the other.
Thanks, yes I will catch on, have reading to do, but am going to buy one now to get started.
THANK YOU! Don
woodsyi
« Reply #1 on: 3 Feb 2006, 07:24 pm »
Wireless also has wired port.  So yes, it is more versatile.  Getting a full mod also gives you flexibility of using either output and know that they are the best that can be.  Good luck.
Charles Calkins
« Reply #2 on: 3 Feb 2006, 07:44 pm »
Don:
  Just make sure you have either DSL or broadband. Wireless routers will not work with dialup.
                                  Cheers
                                 Charlie
ctviggen
« Reply #3 on: 3 Feb 2006, 07:51 pm »
Well, you'll still be able to setup a network, but you won't be able to share the internet phone connection.
Paul_Bui
  • Rode NTK and S-1 microphones
« Reply #4 on: 3 Feb 2006, 07:59 pm »
I'd take advantage of the 30-day SG policy, try the stock SB3, and return if it doesn't work out.
nodiak
« Reply #5 on: 3 Feb 2006, 08:12 pm »
Thanks guys, I don't have dialup, so no problem there.
I maybe haven't done enough investigation in this but I was hearing that the sb3 was more difficult to mod because of internal size...?
Does it matter, sb2 vs. sb3?
There are some wireless sb2's still available, but I thought I should order today or tomorrow.
Don
woodsyi
« Reply #6 on: 3 Feb 2006, 08:20 pm »
I think Wayne found a solution for SB3 mod for now but there is certainly more room in SB2 for mods.  I had a Bybee put in on my digital out and that may not be doable for SB3. Functionally they are supposed to be the same.
Wayne1
« Reply #7 on: 3 Feb 2006, 08:27 pm »
The SB2 can fit larger and different capacitors for the analog output and DC input.
The case design of the SB3 does limit what can be fit inside.
Wireless can be used wired. Full mods include digital and Analog changes as well as internal power distribution changes.
BTW Charles,
My Netgear WP824 wireless router works just fine with NO internet connection, if I just want to play files stored on my computer.
nodiak
« Reply #8 on: 3 Feb 2006, 08:28 pm »
Well, I suppose I should ask this too, you never know. Is the Platinum sb2 just referring to case color? Or anything that matters electronically?
...sigh...
Don
woodsyi
« Reply #9 on: 3 Feb 2006, 08:32 pm »
Quote from: nodiak
...sigh...
Don
Yes, Don.
Now if they come out with a Palladium SB then we are going somewhere...... :lol:
Charles Calkins
« Reply #10 on: 3 Feb 2006, 09:18 pm »
Wayne1:
 You've got the setup with your router that I'd like to have with my Linksys router. But I'll be darned if I can figure out how to set the thing up as you have done.
 You can call me dumdum if you like. The nickname fits me to a tee.
                                               cheers
                                               Charlie
nodiak
« Reply #11 on: 3 Feb 2006, 10:29 pm »
Thanks for your help everyone. Ordered Sb2 wireless.
Take care, Don
drmike
sb2/3
« Reply #12 on: 10 Feb 2006, 10:01 pm »
is a pre amp necessary? do you go from sb to amp, or sb>dac>amp?
thanks,
dr. mike
ctviggen
« Reply #13 on: 10 Feb 2006, 10:03 pm »
Wayne actually wants you to go SB2 to amp (or SB2 to DAC to amp).  I use a preamp just because I have too many inputs and I want to make the system easy to use for the signficant other.
