Other Stuff
Archived Manufacturer Circles
Aspen Amplifiers
GK-1 using Stepped Attenuator
0 Members and 1 Guest are viewing this topic. Read 2158 times.
Felipe
1 Feb 2006, 02:28 pm »
Hi all,
Is this any good ?
http://www.welbornelabs.com/remote.htm
It uses a "shunt" attenuator design.
Seems to me a good way to have Remote volume control, but is it better/worse than the standard pot that comes with the EL GK-1 version ?
regards,
Felipe
aurelius
1 Feb 2006, 07:36 pm »
I've had one on order since 6th January Felipe... I will let you know in a couple of weeks. The main driver for me was a GK1-R remote control code clash with my Loewe Planus TV!
Felipe
Reply #2 on:
1 Feb 2006, 08:27 pm »
Aureluis,
Tuff luck
Can you tell me wich attenuator (10K, 50K, 100Kohm) did you think was best to use with the GK-1 ?
And also, wich brand for the series resistor in the shunt topology ?
(Dale, Vishay, Caddock, Allen Bradley, etc)
Thnks
Felipe
MikeC
Reply #3 on:
2 Feb 2006, 06:43 pm »
Hi Felipe
I have one - well the boards and components anyway. They have just arrived, and I will start working on them this weekend. I checked with Hugh before ordering and he seemed quite impressed from the description on the Welborne site. I went with the 50K version.
Mark will probably have his in his preamp before me - I am looking at further delays with some other parts before I am up and running. I will feedback when it is installed though.
Mike
Other Stuff
Aspen Amplifiers
