surge protection question
0 Members and 1 Guest are viewing this topic. Read 751 times.
kyyuan
« on: 1 Feb 2006, 01:13 am »
Howdy y'all,
I'm in the process of installing two dedicated 20-amp circuits for my system.   I currently plug the digital and the amp into a BPT, and the preamp into the wall.
My question is:  How should I address, if at all, the surge protection issue?
Option A:  install protection at the breaker panel for the whole house; plug the amps into the wall; everything else into the BPT.  Advantage: protecting everything in my house and can plug the amps into the wall.  Disadvantage:  cost and may not be able to find a "audio quality" surge protection panel.
Option B: install one 20-amp protection panel  (e.g. Brickwall industrial) at the breaker panel for one of the dedicated circuits (for the amps) and, use the BPT for the other dedicated circuit (all non-amp equipment).  Advantage: cost less, can plug the amps into the wall.  Disadvantage: may not be able to find "audio quality" protection panel.
Option C:  put a surge protection device (e.g. Brickwall audio) between the outlet and the amps.  Advantage:  lower cost.  Disadvantage: this means an additional device/powercord is between the amps and the outlet.
Option D:  forget about it.  Just install the dedicated circuits; plug the amps into the wall; everything else into the BPT
Option E/F/G:  your comments/inputs are here
Sorry for the long post.  Any thoughts are appreciated.
Ken :D
kyyuan
« Reply #1 on: 1 Feb 2006, 06:51 am »
a mini bump  :D
- p.s. I'll try other sites as well.
  • Speakers....What Speakers ?
« Reply #2 on: 1 Feb 2006, 07:10 am »
I like Option D....but what do I know... :?
    Give it some time for answers...or post in the Lab. Good luck !! :D [/list:u]
ctviggen
« Reply #3 on: 1 Feb 2006, 12:29 pm »
I did something like this (though mine was cheaper):
http://www.smarthome.com/4860.html
You can protect your whole house.  Sadly, I cannot as of yet vouch for performance.  They sell the kind I purchased at Home Cheapo.
Jason Nugent
« Reply #4 on: 1 Feb 2006, 01:43 pm »
I don't know if this helps or not, but Bryston is now selling power conditioners made by Torus power. They have NEMA versions that mount at the panel and provide surge protection on all circuits running from them. There are also rack mount versions.
http://www.toruspower.com
and talk to James Tanner in the Bryston/PMC circle.
