Crimp connector question from newbie.
0 Members and 1 Guest are viewing this topic. Read 1523 times.
robertwstephens
« on: 30 Jan 2006, 03:20 am »
Hello!  I am building a cornet II and I'm on the home stretch.  I am more overbudget than a government project, but enjoying the process too much for any true complaining.  I have been trying to crip on the quick connect fittings to the transformer wiring.  Do I crimp through the pink plastic body?  Does anyone have a recomendation for a good crimping tool they have used or method that works well?  I cannot get a good crimp with regular pliers and am having trouble getting the fittings to hold onto the wiring.  Sorry for such a lame post.  This project would have been impossible for me without this forum and help from contributors.  Peace.  Robert
analog97
« Reply #1 on: 30 Jan 2006, 11:41 am »
Yes, Robert.  You crimp right over the plastic.  Just be careful not to rip thru the plastic insulation.  I think you need a crimping tool, unless someone else knows a particular type of pliers that will provide enough oomph.  I used a crimping tool and had no difficulty.  These are inexpensive and common, something you might also try to borrow.  How did the "solder bridge" work for you?
BillEpstein
This is what I use
« Reply #2 on: 30 Jan 2006, 01:23 pm »
robertwstephens
« Reply #3 on: 30 Jan 2006, 01:37 pm »
Thanks for the response! It looks like I need to make a trip to the store to get a crimp tool. I can only make the leads going to the power inlet switch right now.  I am still waiting for the heatsinks from DigiKey that I ordered in December.  I will use the solder bridge to attach them to the board when they come in.  Otherwise it is ready to go.  I listen to vinyl about 80 percent of the time and look forward to hooking this baby up.  Peace.  Robert
analog97
« Reply #4 on: 30 Jan 2006, 02:08 pm »
I, too am waiting for the heatsinks from Digikey to finish the Clarinet.  They gave me a ship date of Feb 13.  I listen to vinyl 98% of the time.  I predict you will be thoroughly impressed with the Cornet2.  I was, am and will be.  As far as I know, there's not a single bad word out there!!  Post your impressions after break-in.
