C-Series - what's new ?
0 Members and 1 Guest are viewing this topic. Read 3646 times.
raykkho
« on: 23 Jan 2006, 05:44 am »
Can James or anyone advise me the real difference between the C-Series and the non C-Series SST amps, besides the very pretty face plate?
Thanks.
Levi
« Reply #1 on: 23 Jan 2006, 06:06 am »
I addition to cosmetic change, the C-series are not rack mountable.
raykkho
« Reply #2 on: 23 Jan 2006, 06:22 am »
any positive differences then?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #3 on: 23 Jan 2006, 01:55 pm »
The C-Series is the same as the Consumer versions of the SST Series other than cosmetics.
james
raykkho
« Reply #4 on: 23 Jan 2006, 04:09 pm »
Thanks James.
Kevin Brown
« Reply #5 on: 10 Mar 2006, 02:37 am »
Maybe I can ask this here.  An admittedly esoteric question.  :)
I have a 7.1 setup, and I've always gone with a 2 ch amp plus a 5 ch amp.  Obviously, then I only need to power the 2 ch amp when listening to CDs, lps, etc.
I stack the amps (yes, with spacers in between for air flow.  :) ).  But I also stack an AC balanced power box on top.
OK, so I've always looked at the 3B-SST and the 9B-SST.  But the 3B-SST isn't deep enough for me to put the balanced power unit on top.  (It has to go on top, because it's a little narrower than the amps.  Wouldn't look right if it was on the bottom.)
Ahhh, but now there is the 2B-SST C, which *does* have the depth I'd need.
... But I want the greater power of the 3B-SST.  Any chance they'll ever be a deeper version of the 3B-SST?
HPower
« Reply #6 on: 10 Mar 2006, 03:08 pm »
Hey Kevin,
Not to sound like as smart a$$, but they do make a deeper version,
It's called the 4Bsst.
I was at my local dealer just this week and he was mentioning how the 4B is the
most popular model he sells.
The reason he gave was price point:
3B = approx. $3,000 cnd
4B = approx. $3,700 cnd
7B/14B = approx. &7,200 cnd
To me and my dealer, it seems like a no brainer to spend the extra $700 and get
the 4B over the 3B.
Unless someone is very tight for space and wants a smaller foot print (the opposite
 to you), the 4B would be the way to go?
Kevin Brown
« Reply #7 on: 11 Mar 2006, 01:36 am »
In my mind, the 4B-SST doesn't "match" well with the 9B-SST for a 7 ch system.  300W/ch vs 125W/ch or so.
I actually did have a 5B-ST and an 8B-ST for a while, but I wanted a 2+5 combo and not a 3+4 combo.  But I did like that combo.
That's why I think it's curious that the lesser powered 2B-SST C is deeper than the 3B-SST.  I'm betting I'm not the only one who wanted a deeper chassis.  :)
I'm hoping for a 3B-SST C someday.
