What speaker cables are you using with your JVC RX-F10 etc.?
0 Members and 1 Guest are viewing this topic. Read 1409 times.
jasonc
Curious what others are using to work with the spring loaded speaker posts on these amps?
hershey 22
« Reply #1 on: 22 Jan 2006, 02:10 am »
I am using QED Silver Anniversary bare and I like it alot.  I would like to try some others such as the Reality Cables bare but I can't decide whether I believe in differences in speaker cables or not.  I am always looking for that tweak that will give me improvement!  :D
TheChairGuy
« Reply #2 on: 22 Jan 2006, 06:09 am »
Alpha-Core MI-2's (cryo treated), 5' pair with speaker pins.  $163 for the wire, $35 for the cryo.
Can't tell if the cryo helped at all...but, the Alpha Core was the first speaker cable bought that decidedly sounded like an upgrade, not a lateral move sideways.
I was a little concerned about the JVC driving this ultra-high capacitance wire (makes Kimber's look tame in comparison in that respect), but it's simply a great match with the F10.
  • Speakers....What Speakers ?
Re: What speaker cables are you using with your JVC RX-F10 e
« Reply #3 on: 22 Jan 2006, 06:16 am »
Quote from: jasonc
You might try this on your spring loaded posts...worked for me. :D
jasonc
« Reply #4 on: 22 Jan 2006, 01:59 pm »
Quote from: lonewolfny42
Quote from: jasonc
This would really open up my options, my only concern would be that it wouldn't be a fully nuetral solution.  With the addition of the nitro wire as part of the adaptor wouldn't that wire's signature get mixed with whatever speaker cables I go with?  Perhaps it gives one more pursuasion to buy Waynes Nitro cables along with the device?  Then again if Wayne terminated his Nitro amp end with pins it would make the divice useless.
