Hi Andy,
AKSA100N+ will go to 2.5R. AKSA55N+ will go to 3.5R. The 25N+ will go to 3R. I don't recommend a 25N+ down below 3R; it's risky. Either dedicate one module, one tweeter, or use the 100N+.
Brad,
1. would it be a viable option to buy 1 x stereo 25w Lifeforce to drive the foward firing tweeters and use the N25+ for the rear firing tweeters?
2. could 1 x 25w Lifeforce handle the parallel seas drivers?
3. If I do want to try this Orion+ upgrade now, could I swap the 25wN+ with the 55w that is currently driving the mid range drivers, and at least reduce the current demands on that chanel.
I think #1 (and hence #2!) would work OK, though I've not done it myself. The LF definitely has more drive than the AKSA, and for higher frequencies with much lower amplitude than is common with bass amp it would be quite suitable. The LF would bring greater resolution to the front tweeters, which is no bad thing.
Not sure I understand #3; but as a general rule, reducing the rail voltage of an amp increases its tolerance to low impedance loads by improving its SOAR margins (secondary breakdown with difficult loads), and enhances its stability margin by reducing phase shift across the amp at high frequencies. For the lower impedance tweeter load, I'd stick with the lower power amp.
You commented earlier on the bass response of your AKSA100s with the Orion. While you are able to adjust the levels conveniently with the Orion ASP, I would say that I've compared the subjective bass of the the AKSA100 with the LF100 and the latter is subjectively louder, despite measuring within about half a dB. The subjective quality of the LF is different; it sounds louder, too.
Brian T,
How can a ‘cheap’ chip amp compare with the AKSA?
I must admit I found this surprising too, but one thing is certain - people have differing opinions, and choose accordingly. We do this with automobiles, wine, books, all the enjoyable things of life! I don't say he's wrong, just that it's not my taste......
Dan,
I've heard the 801, agree, very nice speakers. I've not heard them up against the Orions, but I'd probably agree with you if I did!! In my opinion, the limiting factor with the Orions is less the many opamps used in the ASP than the power supply for same. It makes a huge difference to the overall sound quality. Just why, I cannot say, but it's the difference between a stunning loudspeaker and one which talks to its owner......
Hugh
