Experience with Multi Channel Processer Pre's?
0 Members and 1 Guest are viewing this topic. Read 2519 times.
ABEX
« on: 16 Jan 2006, 03:55 am »
I have been using a Panny SA-45,but I am going back to seperates and I am going to be looking for a SS Pro\Pre. My main concern is to get the best Redbook playback using one.
I am going to be using an Argon 2004 for my mains and a B&K 5ch. Amp for my Surrounds and CC Speaker and am looking for a Pre that will be capable of having Software Upgrades.
My speakers are Metal Driver Tech mainly and will probably add a Magnepan CC seeing that it is noted for being very transparent where Vocal Info is concerned.
Anyhow what would people suggest in the $1-$3K range that does well for 2ch. Redbook as that is what I use mostly and I do not wish to have that area suffer.
Bel Canto is alittle pricey and was wondering what others have had luck using  that is less expensive.
I have used Rotel,NAD,B&K  pre's plus Passives in the past with B&K and the Passive giving me the best experience. I have read that since Aragon has been taken over by Klipsch I believe they have suffered where quality and  sonic integrety is concerned  so I might not take a chance on using them.
Then there is Outlaw,B&K,Rotel,Emotiva,Anthem look like the affordable choices and I wonder what mmight be the best at not getting in the way of 2ch. playback.
I might be missing other choices also with Arcam,Parasound,Classe and Bel Canto being alittle more expensive.
I would probably wait to see which one that I am looking for that list for less than $3K to show up on the used market.
Which have people found good success with for 2ch. Playback is what I am asking and might be synergistic with my system having 2ch. being my main concern? I do have a vinyl collection,but can get by with just a MM section.
Any ideas welcomed!
TIA
mca
« Reply #1 on: 16 Jan 2006, 04:01 am »
I've had good luck with my Anthem AVM20. Great sound in 2ch and some great deals if you don't mind buying used.
ABEX
« Reply #2 on: 16 Jan 2006, 06:48 am »
MCA-Nope! That is what I do now is buy used as buying new unless it's an inexpensive item I will wait to buy used. To many good deals in used equipment these days.
I picked up a Aragon 2004 amp for $300.  I bought a TCC TC-754 - line-level preamp + MM phono stage just to have around instead of building something myself to tryout for hooking up equipment for $80.
Anyway I'll look at the Anthem stuff and see what they are going used for.
Thanx!
arthurs
« Reply #3 on: 16 Jan 2006, 12:20 pm »
The Krell Showcase is an exteremely nice processor that does 2-channel very well.  You can find them on AudiogoN in your price range.  Worth serious consideration.
jermmd
« Reply #4 on: 16 Jan 2006, 03:42 pm »
I hve the new Parasound Classic pre/pro and it is exceptional for 2-channel playback. Unfortunately, it's wasted because I use my Tact for music. I would recommend the new Outlaw pre-pro and try it out. If 2 channel is weak, buy a seperate preamp for 2 channel. You should easily be able to stay under $2K and still have a state of the art system.
Marbles
« Reply #5 on: 16 Jan 2006, 03:52 pm »
Screw 'em all....
Get a receiver for HT with pre-outs and get yourself a decent 2 channel pre. with HT bypass.
You can sell your 5 channel amp to help pay...
mcgsxr
« Reply #6 on: 16 Jan 2006, 04:12 pm »
I am with Marbles on that one - when I was trying to blend a 2 channel and HT system together, that was my approach.  Works great, for both...
jeffreybehr
« Reply #7 on: 16 Jan 2006, 04:27 pm »
ABEX, unless you need digital decoding for something more than you've mentioned, you'll be better off sonically by spending your money on a 6-channel preamp and NOT another pre/pro.  Let the player do the D-A decoding and buy, say, an Audio Refinements Pre 5 as I did.  It sounds VERY good, especially after a few parts improvements, and I suspect better than ANY preamp/processor.  It's LOTS less expensive, too--I got mine used for c. $600; they retail for something like $1100 including remote.
There are many other 6-channel preamps around, most more expensive.  When I win the lottery, I'm buying conrad-johnson's new $7500 MET1, a tubed 6-ch. preamp with 2 sets of 6-ch. inputs.
ABEX
« Reply #8 on: 17 Jan 2006, 05:03 am »
Marbles?
Are you using a Passive with a By-Pass with the B&K being the HT Processor?B&K always has been a favorite of mine.
That is what I did before in in similar setup using a Leicon Procesor and an FT Audio Passive. It sounded good,but the Processor was out of date.
Now I am thinking the only thing I need in a HT Processor is AC-3 and all the other junk they put in I really never use.
The Krell Showcase is not a bad idea either. Have not checked the Classe Processors out yet. The Rotels are diffrerent ,but I'd want the $3K model because of the better DACs.
The review I read in S-Philes HT edition had high marks for the Aragon Model for 2ch.,which it surprises me.
I am in no rush and will keep an open mind before deciding.
If I was to go the Passive Route again I would definately need to get one that has a remote this time.  I would need to get another outboard DAC with high gain for Rebook. I have no SACD's so that is one reason I feel I really do not need all the other add-ons that most processors have so a used model with good Surround Processing might be all I need.
Thanks for the suggestions!
