What's "Vintage"? Do ...
0 Members and 1 Guest are viewing this topic. Read 2149 times.
andyr
« on: 13 Jan 2006, 03:57 am »
a 20-year old LP12 and Maggie IIIAs made in 1987 qualify?    :D
Andy
Brad
« Reply #1 on: 13 Jan 2006, 04:21 pm »
Definitely.
Welcome Andy!
Tell us about the LP12.
What cartridge are you using?
Power supply upgrades?
What's the rest of your system?
andyr
« Reply #2 on: 14 Jan 2006, 12:24 am »
Hi Brad,
My LP12 is Circkussed and Lingoed (original narrow-case Lingo) but at some stage I will be doing a "renovation" to add the Cetech carbon-fibre sub-chassis.  As I will have to take it apart to fit this, I'm also going to get my afromosia plinth "piano-blacked" ... which I think should look pretty swish!  :-))
As I've got Lingo #1, I suspect something could be done about the power supply and motor ... but both of the current options seems to be expensive!  (Buy a new Lingo or swap to the Orgin Live DC motor.)  But a guy called Mark Kelly over on Vinyl Asylum is developing a 3-phase elctric motor and supply so, when he's got this working, if it sound good it might be a cheaper option!
The rest of my system is listed her under "Systems" ... andyr.
Andy
