What DACs offer I2S input
0 Members and 1 Guest are viewing this topic. Read 1688 times.
gongos
« on: 11 Jan 2006, 10:16 pm »
Does anyone know what models offer this besides the P3A?
jman66
« Reply #1 on: 12 Jan 2006, 01:54 pm »
North Star Design M192 offers an i2s input.
woodsyi
« Reply #2 on: 12 Jan 2006, 02:13 pm »
Quote from: jman66
It uses RJ45 temination -- more wires than P3A.  I don't know if all of them are used or not.
Marbles
« Reply #3 on: 12 Jan 2006, 02:33 pm »
Interestingly enough, Steve Nugents (Empirical Audio) I2S off Ramp uses an RJ45 to I2S cable.  His Off Ramp has the RJ45 jack.  He likes it because it locks the cable (jack) in.  If you are using or going to use the Off Ramp, I would think the RJ45 input would work GREAT.
woodsyi
« Reply #4 on: 12 Jan 2006, 02:35 pm »
Zero one has something similar that uses proprietory I2S cable between the transport and DAC.   Both of these DACs require the signal to ALREADY be upsampled to 24bit 192Khz to be accepted via I2S port.  Steve told me his only output at 96 KHz. :evil:
Marbles
« Reply #5 on: 12 Jan 2006, 02:43 pm »
Quote from: woodsyi
Zero one as something similar that uses proprietory I2S cable between the transport and DAC.   Both of these DACs require the signal to ALREADY be upsampled to 24bit 192Khz to be accepted via I2S port.  Steve told me his only output at 96 KHz. :evil:
That could be.  I have only tried to upsample to 24/96 with Steve's.
The P3a is limited to that right now anyway.
jman66
« Reply #6 on: 12 Jan 2006, 02:55 pm »
The North Star (I believe) also requires a 24/192 upsampled stream being fed into its' i2s input.
BradJudy
« Reply #7 on: 12 Jan 2006, 06:16 pm »
The old Audio Alchemy stuff uses i2s - same connector as the P3a uses.
