cd player 220 to 110 Voltage converter question...
0 Members and 1 Guest are viewing this topic. Read 1237 times.
knac67
« on: 11 Jan 2006, 01:53 pm »
I am looking  to buy a tubed cd player from china. Most of the units are 220-230 volt units. My question is: "Will a converter degrade the sound quality  the unit?"
Thank you in advance for sharing your experiences.
Occam
« Reply #1 on: 11 Jan 2006, 07:23 pm »
I can't speak to the voltage converters sold specifically for that purpose which are typically autotransformers.
I can speak to the use of step up isolation transformers, which can substantially INCREASE the performance of components powered through them. Mains power here in NYC (and I assume throughout the country) sucks, and has a very negative effect. Step up transformers identified as 'medical' will have a shield between primary and secondary which attenuate high frequecy noise as well as minimizing  common mode noise of all frequencies. Assuming they've a adequate va (wattage) rating, they will provide substantial benefits.
Another excellent approach, feasable only if you're confidant in your DIY abilities, is to implement your own balancing powerconditioner, ala the Felicia project -
http://www.audiocircle.com/index.php?topic=18443&highlight=
the only change you would make is wire the primaries of the input transformer in parallel, leaving everything else the same, and you'd get balanced 230vac at the output with substantial powerconditioning applied.
knac67
« Reply #2 on: 11 Jan 2006, 11:22 pm »
Thank you for your reply. I guess I worded the question wrong. I live in USA with 110 voltage, I am thinking of buying a Chinese CD player that operates on 230 volts. Would a step-up transformer that coverts the voltage form 110 to 230 volts have any effect on the audio performance of the CD player? Does impedance matching come into play?
Chris
ctviggen
« Reply #3 on: 12 Jan 2006, 12:53 am »
I think Occam answered your questions.
knac67
« Reply #4 on: 12 Jan 2006, 02:15 am »
Sometimes it takes me more than a couple of readings to understand.
