Quad ESL questions
0 Members and 1 Guest are viewing this topic. Read 1399 times.
studley
Quad ESL questions
« on: 8 Jan 2006, 08:25 pm »
I have 2 questions:
1. Has anyone found that cleaning up the power supply to ESLs (mine are 989s) has a noticeable effect?  (I'm planning on building a Felicia - see The Lab).
2. Does anyone know how many watts 989s draw?
gilbodavid
Quad ESL questions
« Reply #1 on: 10 Jan 2006, 10:23 am »
Hi. I've got esl57's, which respond amazingly to quality power leads. So I can only assume its a case of the more the better. The best is probably a dedicated mains spur, with no fuses or plugs in-line, relying on fuse and protection in the Quads, and a breaker in the supply. This seems to do what $thousands gets with filtering.
studley
Quad ESL questions
« Reply #2 on: 10 Jan 2006, 02:57 pm »
Thanks for that Gilbodavid.
Quad have answered my other question: 6 watts.  I assume that's the same regardless of whether they are playing or idling since the drive power is via the speaker cables - unless anyone tells me different??
Occam
Quad ESL questions
« Reply #3 on: 10 Jan 2006, 03:49 pm »
I see you've found your answer, which seems reasonable. A handy dandy tool I use (the GB equivalent) is -
http://www.maplin.co.uk/Module.aspx?ModuleNo=38343&TabID=1&source=1&doy=search
but it might be depressing to see how much it costs you to power those Pass monoblocs  :(
studley
Quad ESL questions
« Reply #4 on: 10 Jan 2006, 09:01 pm »
Occam
I'm pm ing you. Cheers!
moray james
    • moray james cables
ESL Supplies
« Reply #5 on: 20 Jan 2006, 08:45 am »
Have a look at the supply mods at the Izzy Wizzy page http://www.izzy-wizzy.com/audio/spkr.html also have a look at he Acoustat mod site at diyaudio.com at this address http://www.integracoustics.com/MUG/MUG/tweaks/acoustat/
   Power cords can have a tremendous impact in both directions (good ones and bad ones) so borrow some good cords and check them out. The choke supply mod is also a big deal. I you want to hear the impact of your Quad supply you can do so easily. Wait till after the big power rush in your area (usually after midnight) and listen to an especially well recorded piece of music. Then simply unplug yyour supplies and replay the same piece of music. The diffeence you hear is the supply noise removed. You panels will play for quite some time before they slowly begin to discharge and level will drop slowly. Hope this info helps. Best regards Moray James.
