0 Members and 1 Guest are viewing this topic. Read 3945 times.
Hi,When will the new Force XL sub be available? Specs?I just received my Force sub last week... had I known the XL was coming, I would have waited. Thanks,Will
Thanks for the quick reply. So it sounds like it's just a cosmetic change? Does it sound different than the current Force? I'm just wondering why the change if the amp, driver and specs are the same.Is the Force XL replacing the original Force? Or in addition to?Thanks,Will
Mike,Is delivery for the XL Force scheduled before or after the XL center?Thanks,Ajay
Mike: The new Foce cosmetically looks great! I think you have another winner. I found the original Titan very attractive and it was replaced before I was able to upgrade my Quake (I love my ACI Quake). I know the Force is a great sub but I never found it attractive. Most likely I will order a pair of the new Force.Barry
Are the new Force going to be offered in the same finishes as the Sapphire XLs? Any idea about when the new Force will be available?
