perpetual technologies p1a problem
Rocket
« on: 6 Jan 2006, 02:42 am »
Hi,
I bought a second hand pt p1a a couple of years ago to match my p3a dac.  Over the last few months i have been having an intermittent problem with the music dropping out for very short periods of time i.e. i can see the red signal on the p3a come on and the music drop out.
I've replaced the cdp i was using and i'm still having problems with it.  I do have a problem with the i2s jack on the p1a and have to toggle it a bit to get sound.
Any ideas?
Regards
Rod
Chris_B
« Reply #1 on: 6 Jan 2006, 03:01 am »
What I2S cable are you using?  I had the same problem with a Camelot cable.  Switching to a different cable fixed the problem.
I have a better cable if you are interested.
Rocket
« Reply #2 on: 6 Jan 2006, 05:08 am »
Hi,
I was thinking i might have to send the p1a off to the factory.  I think the problem is the i2s input but perhaps it is the cable.
What type of cable do you have available?
Regards
Rod
mlschifter
    • http://www.av123.com
« Reply #3 on: 11 Jan 2006, 03:24 am »
Quote from: Rocket
Hi,
Regards
Rod
Please do let us know if we can help...
All the best...
mls
