0 Members and 1 Guest are viewing this topic. Read 3198 times.
So there is no need to tag after I conver to FLAC? EAC does all the work??
Yep, EAC will get that info from freedb after you enable that feature by providing your e-mail adress (done w/in EAC). The only thing I do manually (aside from fixing the Genre as has been suggested) is create the artist and album sub-directories in which the compressed (FLAC) files will be saved. Hell maybe it'll do that automatically too, but I don't mind.Don't think you're the only one to be scratching your head trying to get this setup. It had be boggled for a bit. AC member jakepunk ...
Now how do I tag stuff in Monkey media?
i have pretty much decided that Browse Folder s the only way I will be able to do this. I will just have my folders well organized.
