SB3 Analog Mod - Auricap Value?
Horizons
« on: 3 Jan 2006, 06:43 pm »
Not trying to DIY my own Vinnie SB3 analog mod but I was thinking if that Auricap is external, is it possible to change caps fairly easily?
Wondering what value of Auricap Vinnie is using on the output? I have a personal affection for oil caps and I'd like to try these at some point. Auricaps are very good but I think oils are a little warmer and smoother.
Vinnie R.
    • http://www.vinnierossi.com
Re: SB3 Analog Mod - Auricap Value?
« Reply #1 on: 4 Jan 2006, 12:24 am »
Quote from: Horizons
Hi Horizons,
I use 2.2uF Auricaps.
The leads of the caps go through the enclosure.  One end goes to the RCA jack, and the other end is surface-mounted to the board.  This is very fragile and easy to damage if you are not very careful.  :!:
