0 Members and 1 Guest are viewing this topic. Read 18492 times.
Hi GaryI have been thinking about making mods to the digital output section of my sb3, and was wondering what difference the digital transformer made?My initial thought was to take a coax cable, and just solder it inside the SB3. The cab ...
How hard was the DAC to replace?
Why 4.7uf on the output, would 10uf not be more appropriet?
Does removing the OPAMP remove the ability for volume control? What OPAMP is it? (perhaps something better could be put in, if volume control is needed and an OPAMP to make it possible?)
Are schematics avalible for the SqueezeBox3?
Great job Gary! A great thread. I really like your controlled approach.
Gary-I don't understand the value of installing a shielded pulse and then running unshielded wire from it's outputpass the RF card to the output jack.The SB3's ground plane is full of noise, IMO, it would be better to use an external ground sourcefor shielding and use two conducter cable with a shield for internal wiring.
Question why does the unit have two DACs? the PCM1748 and the AK4384VT?
