0 Members and 1 Guest are viewing this topic. Read 5006 times.
This mssg is particularly aimed at Mike of ACI - Mike, reading the spec of both your Force and Titan subs they would appear very, very similar except for the 2" larger woofer size and cabinet size of the Titan. The amp power rating is the same, the frequency range is the same, so why would I buy the Titan rather than the Force. Question two is what are the advantages and disadvantages to buying a pair of Forces vs a single Titan sub? All of the above is for a high-end 2-channel stereo system.Regards,Kevin
Thanks Mike and Harry P for your replies.Mike, I'm surprised that a single Titan will play 3dB louder than a single Force given that their amplifier power ratings are the same. I'm assuming that their efficiency rating and cross-overs are identical so wouldn't a 250 watt amp play a 10" driver as loud as a 12" driver? Excuse my ignorance - just asking so as to learn.Let me make sure I have your info correct: in relative terms and using an index to compare a Force vs Titan sub, if a single Force loudnes ...
Kudos to Mike for his class act of not 'overselling' (he could have pushed dual titans instead) ...With proper placement stereo subs will offer better experience than a single sub. The 3dB is in effect double the outpur power, so Kevin you got the relative numbers right for different subs. Playing louder is subject to combination of driver, volume (of the box/sub) & peak limitation of amp .Yeah RDES (parametric Eq not room correction) can accomodate stereo subs.Cheers,Kishore
Oris98:Some comments and questions Yes I do think a pair of Force is good for your room . . . depending of course how loud you want to play and what kind of material you play. What about sound quality? The Force should never sound boomy, if it does, it is not setup correctly. I'm sure the DD15 is a good sub, but what it sounded like in the showroom really gives us no point of comparison as the room and setup are completely different. The questions:Do you mean the Linn 5150? (the 5120 ...
