Waveguide Question
0 Members and 1 Guest are viewing this topic. Read 16934 times.
YoungDave
Waveguide Question
« Reply #60 on: 19 Jan 2006, 07:39 pm »
Thanks, Jim.
I get it now... the CDWG passive radiator pieceis to attenuate the LF response to better match the waveguide-attenuated 10Khz HF response.  Makes sense.  It is separate and separately priced because some may want to use a different approach, a couple of which (active parametric EQ, tweeter mounting config) have been discussed here.
Thanks for the info.
James Romeyn
Re: rmx
« Reply #61 on: 19 Jan 2006, 08:34 pm »
Quote from: Brian Cheney
The RM/X is currently in stock at $14,900 plus TRT's if desired.
Your humble servant stands corrected, your Excellency.
James Romeyn
Waveguide Question
« Reply #62 on: 19 Jan 2006, 08:53 pm »
Quote from: Skynyrd
Are any of you CDWG users experiencing a warmer (less "hot" or "blaring") overall balance to the RM40's?  I've got my midrange panels surrounded  by 4" wedge foam (thanks to Casler, et al, of course!)...
Skynyrd
I'll tell you what I just noticed, watching Law & Order.  Normally on non-CDWG equipped 30s, when the string section comes in for effect, it sounds very muscial & dramatic, the way Dick Wolf wants it to.  But not a lot of seperation between the sections...nice, but still a bit homogenized.
I'm watching a pretty good dramatic episode from last night, & for a change of pace the political/social slant is in a direction I favor, making it all the more better.  I am not paying any extra attention to the score.
But a few seconds after the strings come in...woa!  I can't believe the string texture...the effect of horsehair pulling over the strings is immense, the sawtooth waveform & 9th harmonic so cleary portrayed.  But the biggest surprise is the seperation between sections.  The violin, viola & cello sections seem perfectly highlighted & in distinct locations, with crystal clear precision.  Yet there is no excess detail, attention or stridency, & the dialog blends with clarity for the most incredible effect.  Musical bliss.  And this is on VHS hi-fi!
Jimmy likey!  B you kicked butt with these things.
warnerwh
Waveguide Question
« Reply #63 on: 19 Jan 2006, 09:27 pm »
Are any of you CDWG users experiencing a warmer (less "hot" or "blaring") overall balance to the RM40's? I've got my midrange panels surrounded by 4" wedge foam (thanks to Casler, et al, of course!) to help tame the "heat" of these very fast and revealing midranges at present
Skynard: Get yourself a Behringer DEQ 2496. You can adjust the sonic presentation any want it. It works wonders with any room/speakers and is a killer bargain for what it does.  I'm not kidding!  The sound in my room is amazingly good and even though I've got an LEDE room with bass traps the Behringer unit took it to another level.
All rooms will have hot and cold spots depending on speaker position etc. Now you can tune to your room without a penalty.
ctviggen
Waveguide Question
« Reply #64 on: 19 Jan 2006, 09:30 pm »
How do you have the foam wedge?  Is it connected to the wave guide?
John Casler
Waveguide Question
« Reply #65 on: 19 Jan 2006, 10:27 pm »
Quote from: ctviggen
There is no need to use the foam behind the CDWG (nor is there space)
It already has specific layers of treatment that fit up against the neopanels.
ctviggen
Waveguide Question
« Reply #66 on: 19 Jan 2006, 10:34 pm »
John,
How are the midranges surrounded by a foam wedge?  Glued to the outside of the CDWG?
John Casler
Waveguide Question
« Reply #67 on: 20 Jan 2006, 12:09 am »
John,
There is no "foam wedge" on the CDWG, The earlier poster who uses the foam wedge has no Wave Guides.
ctviggen
Waveguide Question
« Reply #68 on: 20 Jan 2006, 06:32 pm »
Ah, I got totally confused.  I thought this was a special combination of wave guide and wedge.  You mean to tell me you don't have a tweak for the waveguide yet?  ;-)
