0 Members and 1 Guest are viewing this topic. Read 6820 times.
I also use a wet vac cleaner as well as a carbon fiber brush. But most of my collection is very much USED vinyl which I suspect has been worn with far less lofty gear in its past lives.
Computer tech is here now.I'm using a computer, ripping with EAC, playing with Foobar2K, upsampling with Secret Rabbit to 24/96, outputting with ASIO to an Empirical modded USB I2S Turbo Off Ramp to an EA modded P3a DAC. It's really much easier then it sounds.To me it sounds like vinyl without the noise floor. No digititis, great soundstage and layering. Really, the best of digital and vinyl thrown together without any of the negatives. It's pretty cool.OK, there is a learning curve, and in my case the computer is wired to my stereo, but the new modded SB's are wireless (with their own learning curve).Once you go to a computer based system, I think it would be awefully hard to go back.Oh, one othe negative is no dust jacket art or liner notes...I'm guessing here that the reason it sounds like vinyl to me is the lack of jitter.
