Active analog crossover?
0 Members and 1 Guest are viewing this topic. Read 3689 times.
John Casler
« Reply #20 on: 29 Dec 2005, 01:39 am »
Quote from: Doug Ravizza
 John,
Sorry if this sounds a little dense on my part but, does this mean that the unit has common outputs that carry both the LP and LFE signals? I was thinking that you would still have to somehow "Y" together the LFE and LP outputs to send to the same sub.
Oh, I understand, even after I had the unit, I wasn't sure what it could do.
But, yes, all inputs (LFE and Stereo/Mono) are sent to "common" Sub outs.
No Y-connectors needed.
I don't imagine it would be a good idea to play LFE "AND" Stereo sources at the same time, and I don't intend to try it.
The LFE actually "does nothing" except route the LFE from your Pre/pro to the same outs, and it has a separate volume pot, but no processing/filtering since that is done in your pre/pro.
ctviggen
« Reply #21 on: 6 Jan 2006, 08:47 pm »
Doug, let me know if you want the PDF of the X2.  I do not have the original PDF but I do have a paper copy and can scan that into PDF.
