free software to diagram a room??
0 Members and 1 Guest are viewing this topic. Read 5188 times.
tdangelo
« Reply #20 on: 26 Dec 2005, 08:57 pm »
thanks for the responses.  I measured where I have the speakers and they are 39 from the front wall and 24 from the side ;)  I moved the 4 foot x 8 foot acoustic panels from behind the speakers to directly next to them(fitting into the corner) - I have light now but like Scott said,  I don't think my imaging is quite as good and the system sounds a little hard - Bass is better though...  Gonna give it a few days - maybe all the sunshine is affecting my ears, eheheh
Here's a couple pics of the room.
Tony
tdangelo
« Reply #21 on: 26 Dec 2005, 10:37 pm »
Another:
klh
« Reply #22 on: 28 Dec 2005, 06:06 pm »
I like your set up and room decor. Have you considered a soffit style bass trap? Your room is rather small, and a soffit would look good and make the room feel less cluttered.
tdangelo
« Reply #23 on: 28 Dec 2005, 06:12 pm »
thanks ;)  Whats a soffit style bass trap?  I moved the 4x8x2" panels back behind the speakers where they where before - much better again but no natural light - oh well  :lol:  I moved the 2 2x4x4" panels that were in the rear corners to behind the chair - much better.  I then put the foam bass columes in the rear corners.  Everything sound really good now - quite amazing real that such a small change made such a difference toward better sound...
Tony
WerTicus
« Reply #24 on: 28 Dec 2005, 06:13 pm »
<plug> I can visualise a room if you want to try different layouts and paint colours etc.
I do artwork for interior designers and architects, all 3d renderings and such
pm me for more information
</plug>
ctviggen
« Reply #25 on: 28 Dec 2005, 06:18 pm »
Soffit traps are here:
http://www.realtraps.com/products.htm#soffittraps
I'm buying two stand traps Friday and will have ETF data including these this weekend, though I'm not sure I'll be able to post this weekend.
tdangelo
« Reply #26 on: 28 Dec 2005, 06:40 pm »
ahh - OK - I guess I actually have one of those already ;)  Sorry about the big pics and the bad quality (camera is bad in low light)...
