bi-wiring/ bi-amping Saph 2 or3's/Sub-1s
accent
  • Guest
« on: 17 Dec 2005, 07:13 pm »
Here's the deal... I have (2) ML-9 Levinsons  2 Saphires and 2 sub 1's
and finally got my PAV/PDSD cleared for take-off :lol: .
 I would prefer to use some sort of active crossover (ie..before the amps :wink: )
so that the ML-9s do not have to work to process signals that won't be used. And as this board is the ultimate ACI infosite I am open to any and all suggestions, including getting a Marchand electronic crossover.
  We can explore using my Emerald's as rear or sides on another post as i'll just monoblock those anyway.I might also pickup some Jaguars to play with at which time i'll just move the Saphire to the rear or sides. I will now put on my nomex and await your suggestions.
        Happy Holidays,
        Michael
Anonymous
  • Guest
« Reply #1 on: 18 Dec 2005, 12:04 am »
Instead of adding another layer of electronics in the chain, why not use the passive filters ACI offers. I've used them for years and find them completely transparent, and effective.
Anonymous
  • Guest
« Reply #2 on: 18 Dec 2005, 03:50 am »
Thanks for the reply I'll get a set and see how they work.
        MMM
