DAC recommendations? -Toshlink/AESEBU in, XLR balanced outs.
Sintz
I recently purchased a Behringer DEQ2496 and although very pleased with the results, I'm currently using the DEQs onboard DAC and believe I can do better.
The Behringer has a Toshlink and AES/EBU (Digital XLR) outputs.
I'm looking for recommendations on DACs (new or used) in the sub $350-500 price range that have XLR analog outs (the DEQ is connected to my Parasound Halo P3 using the XLR Direct connections).
Before using the Behringer, I was using the single-ended output from my Denon player with good results (has Burr-Brown HDCD DACs).
I'll admit I don't have any experience with DACs, but would consider anything at this point. Tube or -FET based... doesn't matter. I don't think I can be too selective within this price range, so would consider anything on the warmer side of neutral, if compromises are required.
Recommendations?
Thanks so much!
Marbles
« Reply #1 on: 16 Dec 2005, 03:18 pm »
I'd look at Danny Richies (GR Research) new line of DAC's...
http://www.audiocircle.com/index.php?topic=22942
Sintz
« Reply #2 on: 16 Dec 2005, 03:59 pm »
Quote from: Marbles
Thanks, marbles.
I checked out his site and see moderately priced DAC, but none appear to have XLR outputs.
I've sent him a note requesting information on the availability of XLR analog outs.
Any other recommendations?
Marbles
« Reply #3 on: 16 Dec 2005, 04:03 pm »
regarding the Dac 60, "The back of the unit is also the same as the DAC-72 with fiber optic and coaxial inputs. There is an IEC connector to allow use of any power cable. There is even a section on the back panel for balanced outputs (XLR) to be added if one wished to do so."
http://www.gr-research.com/components/lite_dacs.htm
chadh
« Reply #4 on: 16 Dec 2005, 04:09 pm »
Or, if you were interested in collecting even more equipment, you could get a DAC with XLR inputs and output, and get a Monarchy DIP that accepts the toslink input and has an XLR output.
Chad
chadh
« Reply #5 on: 16 Dec 2005, 04:11 pm »
Wait...that didn't make any sense.  I get all my connectors mixed up.
Sorry
Chad
Pinco Pallino
    • http://www.oddworldz.com/pinco
« Reply #6 on: 20 Dec 2005, 04:26 pm »
Are you sure your parasound has balanced inputs? Often, amps feature xlr inputs but shunt them and continue unbalanced. Look inside or try to get the schematic.
Sintz
« Reply #7 on: 22 Dec 2005, 04:22 am »
Quote from: Pinco Pallino
Pretty sure. It has both XLR ins/outs and forces a bypass of the tone controls when using them. I do notice a lower noise floor using them, so regardless of if they're shunted or not (don't believe so), it's noticably more quiet.
webnick
« Reply #8 on: 3 Feb 2006, 06:28 am »
Hey, Sintz, if I understand your query (not familiar with your equipment), Adcom makes various DACS, the GDA-700 of which, has XLR outputs and accepts a variety of inputs including Toslink (it even processes HDCD).  I have two of them and they sound very good.
bluemeteor
« Reply #9 on: 18 Jun 2006, 11:53 pm »
You may also want to try the Lite DAC 68 or the Lite DAC 38.  Both of these have XLR outputs and AES/EBU digital inputs. You can get a review of the Lite DAC 38 on humble-fi - http://www.humble-fi.com
ryno
« Reply #10 on: 19 Jun 2006, 01:56 am »
RAM has mods for the DEQ2496.
http://www.referenceaudiomods.com
Modding you're behringer and using it's dac could be an option. Fewer components, fewer cables, ballanced outs.
I've never used RAM, but I might mod mine when I get a few other things done. I'd love to hear opinions on what this sounds like.
Ryan
