Looking for a great loudspeaker system
0 Members and 1 Guest are viewing this topic. Read 141008 times.
ooheadsoo
« Reply #220 on: 6 Jan 2006, 05:10 pm »
Quote from: audiophile39
I've been considering the SP Tech Timepiece and Continuum, however with the well-regarded Von Schweikert VR4 Jr, which is a large floor-standing speaker, priced around $4,000, I'm finding it difficult to justify the higher costs of the SP monitors.
It's hard to put conventional speakers like the VRs in the same head to head category with something with controlled directivity.
skrivis
« Reply #221 on: 6 Jan 2006, 06:06 pm »
Quote from: ooheadsoo
That assumes that CD is always of benefit, and that more "conventional" designs have serious enough problems with directivity to matter.
Personally, I sit in one place when I'm "seriously" or "critically" listening. The behavior in other directions may not be as important. (This gets into the argument about flat power response...)
My speakers sound fine when I'm walking around or in another room. My listening room is fairly large and reasonably dead, so early reflections may not be as much of a problem. (Later reflections are not perceived as part of the original event due to the precedence effect.)
The flat power response camp says that you want the sound that will be reflected by the room to be flat (or at least even in all directions) so that the reflected sound won't change the tone of the speakers as a whole. Implicit in this is an assumption that all frequencies will be reflected evenly by the room. I don't think that's normally the case.
Maybe csero will see this thread and jump in. He's got a good handle on reflected sound. :)
Anyway, I guess what I would say is that there's room for different schools of thought here.
skrivis
« Reply #222 on: 6 Jan 2006, 08:47 pm »
Quote from: avahifi
In looking at the Fried website and the info on the Model 7 referenced above, I came across the following:
>>Properly implemented series networks provide superior driver coherence, increased dynamic range and introduce a Doppler effect similar to live music that increases the sense of realism.<<
The "introduce a Doppler effect" really worries me.  I would think that a loudspeaker should not "introduce" anything at all. This kind of falls in the order of "we use good sounding woods" and so  ...
Just FYI, there's a good description of the "Doppler effect" at:
http://sound.westhost.com/doppler.htm
bhobba
« Reply #223 on: 7 Jan 2006, 12:31 am »
I am confused by this.  The base cost of the Timepiece 2.1 is $2995.  Of course that is the base model with no high gloss finish which does nothing for the sound - having such an option is a big plus IMHO.  Now that Bob has dealers it should be a simple matter to pop in and have a listen.  Only you can decide if it is worth the money or if you prefer the Von Schweikert at $4000.00.  Bobs posts on their engineering convinced me of their superiority to the vast majority of speakers - but I am a techo oriented type guy.  Of the speakers I consider may be better such as the Orion or WAR Reference 1 I was also looking at (and it is a big may) it was by far the cheapest.  I believe when Frank has a listen to the Timepieces he will be suitably impressed - whether that translates in them being exactly what he is after is something I and I suspect others are very interested in.  In particular I consider the VMPS 626R would provide tough competition for the Timepieces and Franks take on that speaker I am looking forward to as well.
Bill
ooheadsoo
« Reply #224 on: 7 Jan 2006, 02:28 am »
Ears are easily deceived.  If you have a conventional room, I would recommend using an spl meter and test tones to confirm your hearing.  The power response in waveguide speakers are also more linear than in conventional designs.  The dispersion is also more linear.  It's not just controlled, it's also considered "constant" in a limited fashion.
If you only listen in a limited area, you might be happy to find out that the imaging with controlled/constant directivity speakers tend to stay locked in place, rather than stray to the two poles as you approach each one, as they do in conventional designs.  For example, with conventional speakers, I can hear the image shift if I just move my head a fraction of an inch.
Rocket
« Reply #225 on: 7 Jan 2006, 03:11 am »
Hi Bhobba,
But considering the reputed quality of Bobs speakers I have no doubt dealers in Australia will soon be found.
And i can imagine how much they would cost in Australia  :o.  Its my experience that you can typically increase the price by 2 - 2.5 when importing speakers to Australia.  I think vmps 626r (with spiral tweeter and no options) cost almost $3000.00 and the dealer sells direct over the internet.
The war audio reference 1's are very nice but i like some of their other speakers better (just my personal taste).
Hope Frank finds the speakers he needs for his business.
Regards
Rod
stryder
« Reply #226 on: 7 Jan 2006, 05:15 am »
Quote from: Rocket
Well, on that note, here is a tally of what has been recommended so far.
I did not count speakers that were wayout of his price range (Certain B&W models or were no longer manufactured (Dunlavy SC-III).  I also did not count speakers recommended, but not identifed 9at least by manufacurer) such as those built by Jim Winey and Brian Cheney as I did not feel like Googling them just now.
Apologies if I missed any recommendations and my columns don't seem to be lining up right.   :oops:
Recommendations a/o 01/06/06
Speaker      Unique (Poster) Recommendations
Salk HT3          5
ACI Sapphire XL      4
SP Tech (unspecfied)      4
SP Tech Continuum 2.5   4
SP Tech Revelation       4
VMPS (unspecified)      4
Daedalus DA-1      3
Green Mountain Continuum    3
The moddded B&W      3
Avantgarde Duos (used)   2
Avantgarde Unos (used)   2
Legacy Focus       2
SP Tech Timepiece 2.1   2
Vandersteen (unspecified)   2
VMPS RM 30      2
VMPS RM-40      2
ACI Panorama      1
Aerial Acoustics (unspecified)   1
ATC SCM100      1
ATC SCM50      1
Audio Physic (unspecified)   1
AV123 Ref 3      1
Bamberg BESL Series 5 MTM   1
Coincident (unspecified)   1
Custom Selah      1
Dynaudio (unspecified)   1
Dynaudio D-28       1
Ed Frias (Unspecified)      1
EFE t-22cf (Ed Frias)      1
Ellis Audio (unspecified)   1
Ellis Audio 1801      1
Exodus Audio 2641 (finished)   1
Focus Audio       1
Fried (unspecfied)      1
Fried Model 7      1
Green Mountain Audio (unspecified) 1
Harbeth (unspecified)      1
Harbeth Monitor 40      1
Harbeth Super HL5      1
Hi-Vi Planer RT8       1
Lorelei Odessey      1
Madisound (unspecified, finished?)1
Magnepan MMG      1
Martin Logan Vantage      1
Merlin          1
Morel 33         1
North Creek Music Systems (unspecified)   1
Omega Aperiodic 8s      1
Ridge Street Audio Sason   1
Selah Audio Peridot      1
Selah Audio RC3R       1
Shahinian Diapason      1
Sonus Faber Grand Piano   1
Spendor S5e      1
Spendor S8e       1
The World's Best Loudspeakers
(unspecified)      1
Thiel 3.6         1
Thiel 3.7         1
Totem Forest       1
Vandersteen 3A      1
Vandersteen Quatro      1
VMPS RM2         1
Von Schweikert VR4 Jr   1
Von Schweikert's VR-4 HSE   1
And finally...
Sumatran full city roast, espresso grind, brewed in a Bodum Mini-eSantos  :D
Shields up!
Michael
avahifi
    • http://www.avahifi.com
« Reply #227 on: 7 Jan 2006, 03:39 pm »
Well thanks much Stryder for the tabulation, you saved me a whole lot of work!
I will remember that when you place an order with me. :)
Frank Van Alstine
Rick Craig
  • Selah Audio
    • http://www.selahaudio.com
Measurements
« Reply #228 on: 7 Jan 2006, 04:01 pm »
Frank,
What's your take on measured perfromance of a speaker? I know the B&W's you have were well-engineered and the measurements thoroughly documented. I still have a Don Keele review from Audio magazine  :)
The reason I ask is that it's hard to make a comparison since some of the companies suggested to you publish few or no measurements of their speakers. I've even seen some show response curves from a simulation program! While the most important thing is how the speaker sounds to you I (and many other designers) firmly believe  that a credible manufacturer should be able to back up the performance with good measurements.
 If they don't show any graphs then it always raises a red flag to me. I ask myself - if your product performs well then why not provide potential buyers the information? Two answers come to mind. 1) They don't have the capability or competence to measure their speakers and / or, 2) the graphs will not match their sales pitch and quoted specs.
Sorry to get on my soapbox but maybe this will generate a positive discussion.
Tom
« Reply #229 on: 8 Jan 2006, 03:31 am »
In the 1990s I used a full AVA FET-Valve system driving the B&W 801 Matrix Series II with the Van Alstine crossover mods as my reference system.  I did the mods myself based on Frank's instructions in Audio Basics.  In a moment of weakness, I sold the B&Ws, regretting the decision almost from the moment they were gone.
I'm sure Frank's electronics are better now than they were then, and even then they made the B&Ws sing.  While I chose to "move on" to other electronics as well, not all moves are up in performance, as you know, and I might well return to AVA products someday.  They certainly were extremely high value for money when I owned them, and from what I've heard from the newer products, as well as heard others say, they still are.
I've read this thread with great interest and learned a lot about products I did not know much, if anything, about.  Frank’s criteria are quite tough, actually.  Six thousand dollars sounds like a lot of money, but in today’s market, to get a truly full range speaker that clearly exceeds the performance of the B&W 801 Frank is working with is not as trivial as it seems.  For one thing, bass extension at fairly high volume and low distortion seemingly is no cheaper in inflation-adjusted dollars than it used to be.
That said, here's my general guidance to for Frank, who admits to being a bit of a hermit.
1.  If you plan to sell or at least recommend the product to your customers, you want a  product whose manufacturer is financially stable and can actually deliver his goods within a reasonable amount of time.  You want a company which can deliver its products within the same general time frame as you can deliver your electronics.  This is basic for customer satisfaction, in cases of system buyers.
2.  Before you get in bed with any speaker manufacturer, no matter how nice a guy he is, check out his financials with Dun & Bradstreet and contact his dealers to see what kind of relationships they enjoy from a business standpoint.  If the manufacturer has no, or few, dealers, consider well whether this is a plus or a minus.  If a company has been making speakers for years but only has a few dealers and does not profess to want it that way, what does that imply?
3.  If there are any other audio electronics designers you are friendly with and whose work you respect, I suggest you contact them to see what speakers they use as references for their design work.
4.  Similarly, if there are any audio reviewers whose views you respect, find out what they use as their current relatively affordable reference.  A reviewer who has been reviewing products for a long time has extended experience with far more speakers under controlled circumstances than the average audiophile or the average manufacturer.
5.  You want a speaker which has a well-defined frequency balance.  If all frequency ranges are adjustable, then how can you tell what your electronics really sound like in terms of balance?
I'm afraid that eliminates the VMPS RM40 speakers from the running.  While I have heard these speakers sound very good in dealer auditions, everything about them is adjustable over a fairly wide range, from the lowest bass and bass Q (adding or removing putty from the passive radiator) to the highest treble.  The level controls for the upper ranges have a very wide range, are not marked for reference level, and very small rotations have significant effects on the sound.  I seriously doubt that most users even have a "matched pair" as you would understand that concept.  Also, the RM40 design is a moving target, constantly changing, the latest change involving the addition of a constant directivity waveguide which will necessitate a complete crossover overhaul.  Do you really want that kind of speaker design as a design reference for your electronics?
Besides, from the RM40 and RM/X auditions I've had, both speakers have significantly leaner midbass and lower midrange sound than the B&Ws you are used to.  If you like the generous warmth of the B&Ws, you would probably not like the VMPS speakers.
The Legacy Focus 20/20 is one you should hear.  It's overall balance and midbass/lower midrange generosity is more in line with what you would expect.  In my opinion, it is fully the equal of the VMPS RM40 in overall performance, it has much higher sensitivity, and will play louder for those who want to listen at live rock concert levels.   http://www.legacy-audio.com/2004/focus2020.html
5.  Perhaps you should consider springing for the current B&W 801D at $16,000 a pair as your design reference.  Yes, it's far above your price range, but the current B&W line has good products at much lesser prices which you could recommend to customers.  The 801D has a 15" woofer, a cabinet at least as big as the 801 you're using, it is rated to go lower than the 800D by B&W and is self admitted by B&W to be fuller in the bass than the 800D.  It could just be exactly what you are looking for, albeit far above the $6,000 limit you stated.  B&W speakers took a detour for many years in terms of their high frequency balance, but with the new diamond tweeters now have a high end fully competitive with the best.  The limiting factor of the B&W is the Kevlar midrange, but even it is vastly improved over earlier versions.  http://www.bwspeakers.com/index.cfm/fuseaction/products.models/Label/Model%20801D
6.  I think you definitely should audition the SP Technology speakers, just because the designer is clearly a level-headed engineer like you.  I have never heard any of Bob's speakers, but now I want to.  The discussion of his designs on his Web site and in this thread is exceptionally coherent and I am in tune with his world view.
7.  That said, beware of speakers aimed at the current professional audio market.  This market is driven by the needs of pop and rock music studio engineers for high SPLs and what passes for "dynamics," which usually means "startle factor" on hugely loud transients.  There is a lot of talk about "chest crushing" bass.  When did you last feel bass crush your chest in a concert of live, unamplified classical or jazz music?  It doesn't happen.  It happens at rock and pop concerts because that's the kind of bass that PA speakers produce at extremely high volumes.  Do you want your design reference speakers to sound like PA speakers?  Such speakers often cannot reproduce string or woodwind tonality to save their designers' skins and fail to reproduce subtle nuances at the other end of the dynamic spectrum at any sane volume level.  There are exceptions, of course, but if the designer does not use the sound of unamplified classical music in a good hall as a reference, you are moving far from the sound of the B&Ws you know and love.  Consider yourself warned.
8.  You can buy a slightly used pair of most any speaker you want on Audiogon for no more than half its new price.  If you can't find it there today, just wait a month.  Audiophiles change speakers like they change socks.  How else could the cottage industry that is high-end audio support many hundreds of speaker manufacturers headquartered in the United States alone?
9.  Finally, and this is really an aside given your goals, if you'd enjoy reading about a labor of love, speaker-design wise, spend some time at Siegfried Linkwitz' Web site.  I say, "some time" because it would take a long time indeed to explore all the highways and byways of that site.  The Web site is as much a labor of love as his speakers appear to be.  While his Orion speakers do not meet your requirements at all (they are actively quad-amped with a proprietary electronic EQ/crossover and use dynamic drivers in a dipole configuration), I think you will come away with respect for why he is doing what he is doing with that speaker, and for how affordably he is making these available to the public.  http://www.linkwitzlab.com
ooheadsoo
« Reply #230 on: 8 Jan 2006, 03:44 am »
"There is a lot of talk about "chest crushing" bass. When did you last feel bass crush your chest in a concert of live, unamplified classical or jazz music? It doesn't happen."
That looks like a fine post, and I admit I haven't read it all yet.  However, my chest gets pounded every time the drummer kicks that kick drum and especially hard whenever the big bass drum in the orchestra gets a nice wallop.  Big time.
bhobba
« Reply #231 on: 8 Jan 2006, 04:57 am »
First congratulations to Tom on one of the best and most enjoyable posts it has ever been my privilege to read.  Well done.
Regarding your comments on chest thumping bass I agree it only occurs on some material - sure.  And that material tends to be in the pop/rock genre -  but as another poster said - you also hear it on kick drums etc.
My take is that a speaker should faithfully reproduce what it's fed - if that is impact-full bass then what you should get out - impact-full bass.   I purchased a pair of SP Timepieces because they look like they have the least number of compromises of nearly all other speakers I looked at.  That and Bob struck me as an engineer who really knows his stuff - and is level headed to boot.  Those that also meet that criteria such as the Orion and WAR were much more expensive. I listen at low to moderate levels so I will rarely if ever make use of the Timepieces dynamics.  But does it make me feel good to know that on the rare times I may wind up the wick a bit they will handle it without problem? - you bet it does.  And classical music peaks can reach over 120db.  I do not want to spend the money on an amp that can reach that (over 1000 W) but knowing the speakers can sure is a comfort.
Bill
warnerwh
« Reply #232 on: 8 Jan 2006, 06:53 am »
After hearing the B&W you recommend myself and others were quite unimpressed, especially at the price of 16k.  In my opinion the RM 40's in my listening room sound better for far less money. The two other people with me felt the same way.  I'd like the sound of the 801 Matrix III's very much and wanted a pair so was quite surprised to not find the newer model as great as it had been hyped.  They certainly aren't as transparent as the RM 40's which I believe is what Frank needs for hearing the differences between electronics.
skrivis
« Reply #233 on: 9 Jan 2006, 02:34 pm »
Quote from: stryder
Ok, I can agree with a full city or full city + (basically just into 2nd crack) for a Sumatran. A really fine grind for a vac pot can introduce a lot of sediment though. I also don't really like the Bodum electric vac pots. They don't give you enough control over the brewing process. In particular, they don't seem to keep the grinds and water together long enough. Maybe this is why you go with a really fine grind?
I think the standard non-electric Bodum Santos is a much better brewer... :)
konut
« Reply #234 on: 9 Jan 2006, 02:50 pm »
Actually that was me that originally posted that in a completely different thread.  :!: The filter is such that I don't get too much sediment. I decant right after brewing and throw away the last 1/4 oz. I agree the electrics arn't perfect and I brew manually shutting down before the top starts boiling. And I think thats the critical factor, the temperature, not the time. I love the convenience  of the electric. Also, its very efficient. I only use 28 grams of grounds for 23 oz of brewed, full bodied, smooth, coffee  :mrgreen:
edit: the finer grind addresses the lack of time. The critical factor is to clean the filter with a solvent type cleaner after each use, otherwise filter blowouts occur. I've never had a blowout in  1 and 1/2 years of use. The cleaner is Rochester Midland Spra Kleen.
skrivis
« Reply #235 on: 9 Jan 2006, 03:42 pm »
Quote from: konut
Hmm... with a pH of 13, please be really careful with this stuff! :)
konut
« Reply #236 on: 9 Jan 2006, 04:39 pm »
The cleaner comes in a i gal jug and is diluted 20 to 1. No problems so far.  8) ENOUGH CAWFEE TAWK!  :lol:
avahifi
« Reply #237 on: 9 Jan 2006, 05:11 pm »
OK, knock off the coffee pot pots please.
Of course there was the story of the Texas college star football player who was on the verge of flunking out and he was the basis of the team's success.  His flunking out was unacceptable so the teachers all got together and made him up a special test to keep him in school.
They took him into the test room and said "Here is your test.  Spell the work "coffee" and if you get any one letter right, you pass.
The Texas star sat and pondered for a few minutes and then started:
K
A
U
aaaaaaahh ???
P   H   Y
Kauphy!
Now, no more kauphy pots here pleze.
Frank Van Alstine
Hogg
« Reply #238 on: 10 Jan 2006, 12:55 am »
Frank,
        You didn't mention in the post what you plan to replace the Biro L1's with in your product line.  Is Mithat Konar back from Turkey designing new speakers?  Thanks.
        Jim
stryder
« Reply #239 on: 10 Jan 2006, 02:51 am »
Quote from: konut
Actually that was me that originally posted that in a completely different thread.  :!: ...
Actually, Konut, that was your Dec. 14th post in THIS thread.   :o   I was simply tallying all the recommendations -- and that seemed to be one of them.  I am new here.  Folks will catch onto my sense of humor someday.  My wife has been trying for 23 years.  She is almost there.
I,too, think Tom posted some very sage advice.  Since you are a self-admitted hermit, Frank, have you given much thought how you will begin to audition speakers?
