0 Members and 1 Guest are viewing this topic. Read 8843 times.
Jim, will the version 15 firmware sound better if I'm only using the SB's digital output? Thanks.
The firmware seems to affect both outputs. My suggestion is, unless you are running directly into an amp, to disable the digital volume control. It is reccomended to do this on the Slimdevices website (somewhere) and will make the issue of which firmware you use a moot point. You don't need two volume controls and disabling it made a big improvement in sound quality in my system. I've been preaching this quite a bit in this forum as I really feel the Squeezebox is not going to give up it's best sound untill this is done. And it's best sound is very, very good.
The difference in sound quality was supposed to be due intirely to the different volume curve in the new firmware. jholtz, you are saying with the volume control disabled you can still hear a difference? Aiy-yaaa! I will have to roll back to 6.1.1. and see if I can verify that. I have the latest which was supposed to have rectified the problem and I thought it sounded ok. I will do that tonight. EProvenzano, to disable the volume control open Slimserver and look for Player Settings in the middle, or so, ...
It's better not to worry too much about it and just enjoy listening to music.
It's not a dramatic difference but it is significant enough to be clearly audible, in my system anyway.
With those speakers I also could hear anything.
To disable the digital volume, would I simply turn the volume all the way up?I've fumbled around the settings in Slim Server and couldn't find where to disable it entirely.
I've finally had a chance to compare the 1.5 firmware to the latest with the volume bug patch and I have to agree with jholtz that the 1.5 firmware sounds better even with the volume control disabled. Cannot imagine why that would be and it was contrary to my expectations. Another unexplained mystery of the universe.
Question, is the 1.5 firmware in V6.1.1 of SlimServer?
jholtz,Thanks for the offer, but I was able to download V6.1.1. I know that I read that some people have converted v6.2.1 back to firmware 15, not sure how to do this correctly, but is there any advantage to doing this?
