0 Members and 1 Guest are viewing this topic. Read 8781 times.
Has anyone tried Yahoo's Music engine? It allows you to rip your cd's in a number of different formats including FLAC. It seems like this would be easier than using the EAC/FLAC combo. I am totally clueless when it comes to this stuff, I was just looking for the simplest solution to archive my CD collection in the FLAC format.I would appreciate someones opinion on whether this Yahoo ripper works the same way as the other ways described here.Thanks,David
I asked this question a million times in prior entries, and no one was able to point to a single technical reason that FLAC is better than ITunes for ripping. Just go with ITunes lossless, and be sure to click error correction on. FLAC is too much of a PITA.
For the simplest, could you not simply use WAV files? EAC will do that right out of the box, with no additional s/w of any kind....
[As I understand it, the big downside of wav is the lack of tags, besides the larger file size. The SB needs the tags to function properly right?Todd
